Old 12-10-2003, 12:34 PM   #1
Bernie
Bummer !!
I bought a pair of cast aluminum Moroso valve covers on e-bay. The paint didn't look so good so I stripped them. I was having new exhaust manifolds powder coated (I'm going from 2wd to 4wd) The place that does the powder coating was short of work so they offered to coat the 2wd manifolds in the hi temp coating and the brackets and valve covers in satin black, all for a very modest additional fee. The valve covers look beautiful ! I go to install them, they are the tall ones, won't work in the 4wd position. Bummer !
Bernie
Bernie is offline   Reply With Quote
Old 12-10-2003, 12:36 PM   #2
Yukon Jack
Post Whore
Yukon Jack's Avatar
That is a bummer, I imagine using the hammer to make clearance or a short body lift are out?
1970 Blazer with a 400 sbc and 4" lift
1980 Pontiac Trans Am, 455 Oldsmobile
2012 Kawasaki Concours 14
Yukon Jack is offline   Reply With Quote
Old 12-10-2003, 12:43 PM   #3
Bernie
I seriously thought about the hammer, but I 've redone the cab off the frame in torch red and it would take a lot of pounding to make the covers fit. Also thought of moving the engine forward. Probably just repeat the process with short valve covers.
Bernie
Old 12-10-2003, 01:52 PM   #4
jhow66
jhow66's Avatar
Cut the corner off cover -have someone weld a flat piece back on -recoat.
56 Chevy Bel-Air 2dr. HT (purchased new)
71 Chevy Cheyenne SWB PU (502HO)
65 GMC short bed step--work in progress and my gofer
jhow66 is offline   Reply With Quote
