04-20-2020, 10:38 AM | #1 |
Will it hit? Acceptable header to frame clearance
I have the typical areas of concern with my headers... done plenty of research and never found a definitive answer on what is to be considered a general "safe" clearance between frame and header.
I would assume that the engine moves more torsional than it does side to side. 72 C10, new motor mounts, hedman elite super duty, 1 5/8 tube This photo shows a 3/16 drill bit can fit between header and frame View from front |
04-20-2020, 03:02 PM | #2 |
Post Whore
Re: Will it hit? Acceptable header to frame clearance
3/16" is a bit tight, but you have to look at how the engine is expected to move. They generally try to lift on the drivers side and drop slightly on the passenger under acceleration then on shifts it drops back down and back up. The engine as it comes up generally moves to the side a bit towards the passenger side. The passenger side is the pivot side if you will . The harder the shift the more violent the engine movement is. If your headers aren't coated it will not hurt anything to dent the tube for some additional clearance. You may even be able to dent them if coated if you are both careful and lucky. Neither one comes naturally to me.
If you run them as they are and they hit the frame regularly eventually it causes the gasket at the head to fail. The PO on my Burban just took a torch to the frame so he could use some Chevelle headers.
Thanks to Bob and Jeanie and everyone else at Superior Performance for all their great help. RIP Bob Parks. 1967 Burban (the WMB),1988 S10 Blazer (the Stink10 II),1969 GTO (the Goat), 1970 Javelin, 1952 F2 Ford OHC six 4X4, 29 Model A, 72 Firebird (the DBP Bird). 85 Alfa Romeo If it breaks I didn't want it in the first place The WMB repair thread http://67-72chevytrucks.com/vboard/s...d.php?t=698377 |
04-20-2020, 03:47 PM | #3 |
I clearanced off 1/4 inch of the frame rail. After 10 years of abuse neither the frame or the header show any contact.
1972 C10 SWB, Air, PS, PB, 350/350THM. Second owner. 1965 Corvette roadster, 44K miles, 327/365 SHP, 4 speed, side exhaust, knockoffs, teak, second owner (bought in 1970), Have ALL numbers matching components. My frame off restoration thread: http://67-72chevytrucks.com/vboard/s...d.php?t=556703 |
04-21-2020, 09:09 AM | #4 |
Thanks for the feedback. I might take it easy and see what happens...
P.S. - your build thread is pretty awesome Lee! |
04-21-2020, 05:23 PM | #5 |
Thanks, have about 25k miles since the frame off. It’s still fun to drive and gets out multiple times a week.
