Steering column parts
I am currently trying to rebuild my column from my 70 C10. Its a 3 OTT and I was able to find some of the parts online but I can not find these two. One is the backup lights switch and the other is like a plastic bushing with a black rubber bushing around the outside of the plastic. I'm not sure what to call it. I have been unable to find either for sale online. Any chance someone here knows where to buy these? Thanks!
Re: Steering column parts
Also I assume the reverse lights switch is bad. It looks beat up pretty bad but it may still be good. Not sure what a good one should look like. Also my truck hasn't run in over 20 years so I didnt get to ops check them before removal.
![]() Join Date: Dec 1999
Switch at LMC #36-0661. $14.95 #2 in switches for ‘70 with manual 3 speed.
Smitty '71 Short Fleetside Spring Valley, Ca. |
There are a couple people on the board who rebuild columns. Maybe if you do a search on the this page through google. You might find one of them and determine the terminology and possible a source.
#6 | |
The Older Generation
Rubber ring and thrust washer. Part numbers #3902563 and 3879747. Read this thread: http://67-72chevytrucks.com/vboard/s...d.php?t=790322 The parts you need are #39 & #40 in the parts image. LockDoc
#7 | |
#8 | |
![]() Join Date: Jul 2015
Googled they come up as GM numbers>
Yes, they are original GM numbers. LockDoc
I ended up sourcing them from a restoration shop that specializes in our year model trucks. They are semi local to me and a great help. Thanks again.
#12 | |
No problem, glad you found some. They can be pretty hard to find. LockDoc
