Old 12-10-2003, 01:07 PM   #1
stan79chevy
stan79chevy's Avatar
12 bolt rear??'s
i have a 12 bolt rear in my truck now and i have a 2wd parts truck with a 12 bolt rear they look the same the only differance i see is that the 2wd has 5 lugs and the 4wd has 6 lugs. could i put the 2wd rear under my truck and stick in my 6 lug axles?
79 chevy k20 350/350/205/D44/14bFF
4.56 gears rock
LWB pimer black
01 S-10 ZR2 extended cab
4.3/4L60E/233
3.73 gear 31" DICK CEPEK CRUSHERS
stan79chevy is offline   Reply With Quote
Old 12-10-2003, 01:11 PM   #2
gn4u2c
gn4u2c's Avatar
should work I have seen it done with a 10 bolt
gn4u2c is offline   Reply With Quote
Old 12-10-2003, 02:56 PM   #3
Mike C
Mike C's Avatar
2 wheel drive is coil spring usually. But if not, they have a 42.5" spring center while the 4x4 has 40" centers.
44 Willys MB
52 M38A1
64 Corvette Coupe
68 Camaro 'vert LT1 & TH700
69 Z/28 355 12.6's @110
72 Jimmy 4WD 4spd 4" & 35's
02 GMC 2500HD 4x4 Duramax
Old 12-10-2003, 04:00 PM   #4
wildwood
wildwood's Avatar
All the inards will work though. The axle shafts will be the same (other than 6 bolts) carrier is same but check the ratio on the 2wd will most likely be higher like 3.07 or 3.42. If you are using a gear ario of 3.73 or higher (numerically) you will need the carrier to match. You must match your ratio front and rear, I'm sure you realize that, but just thought I'd mention it.
You can't get out if ya don't get in
wildwood is offline   Reply With Quote
Old 12-10-2003, 08:18 PM   #5
stan79chevy
right now i have the 3.42
the truck with the 12 bolt has either a 3.73 or 4.11 and that is what i want. i was just thinking it would be easier to switch out the whole rear instead of messing with all the guts. my truck is a 79 and the parts truck is an 82 2wd
4.56 gears rock
LWB pimer black
4.3/4L60E/233
Old 12-10-2003, 09:57 PM   #6
Destructo
Measure the spring perches on each and see if their different, if their the same it will work.
Destructo is offline   Reply With Quote
Old 12-20-2003, 06:49 PM   #7
carhhauler
how do i tell if i have an 81/2 or 10 inch rear
carhhauler is offline   Reply With Quote
