Old 04-21-2020, 11:15 AM   #1
gmc396
Strange, LOUD noise after engine is turned off
I have a '68 GMC 396 that I've owned for 7 years. It's a summer ride for me as I live in WI. I got it out last week and drive to get my mail daily. It's about a 5 mile RT.
When I pull into my garage, I typically turn off the ignition and let the truck roll into place. I do this to keep the exhaust smell out of the garage (the exhaust pipes exit just behind the rear wheels). Yesterday, when I turned the truck off, the noise began. It sounded like an electric motor building up in RPMs, but also very mechanical and loud. Never heard a noise like this before. When I came in the house, my wife said she heard it and thought I had my chain saw out.
I thought maybe the engine was dieseling (rarely does that) so I put on the brake and let out the clutch but the engine was stopped. But the noise continued. I was concerned of a possible fire so started the truck and backed it out of the garage.
I turned off the engine and opened the hood. The noise continued, very loud. I could see nothing. Finally it wound down like a big electric motor and stopped.
I couldn't see anything wrong. After letting it sit, I started it and put it back in the garage. No noise.
Any ideas of what that noise was???
Thanks for your help!
gmc396 is offline   Reply With Quote
Old 04-21-2020, 11:40 AM   #2
Wootdog
Wootdog's Avatar
Re: Strange, LOUD noise after engine is turned off
was the heater fan on by chance?
1967 C10
Got it back after three years
Boy I sure missed Peppy
1969 Chevelle
1990 IROC Z Convertible
2002 Silverado LT
Wootdog is offline   Reply With Quote
Old 04-21-2020, 11:59 AM   #3
Willys_MB
Willys_MB's Avatar
Maybe your starter is running after you turn the truck off? That's the only electric motor I can think of other than the heater, but the starter is pretty loud. Does it do it if you stall the engine, too?
1968 GMC C2500 Long Bed Fleetside
Willys_MB is offline   Reply With Quote
Old 04-21-2020, 01:23 PM   #4
hamjet
hamjet's Avatar
Do you have electric cooling fans that run and possibly have a leaf or debris hitting the blades?
Thanks, Joe..
1969 C/10, 348 C.I., 3X2 bbl. V8, 2004r , LWB.
hamjet is offline   Reply With Quote
Old 04-21-2020, 01:32 PM   #5
Dragcamaro
Greetings, Fellow badger!
If it does it again, are you able to disconnect the Negative battery cable to isolate if it was an Electric issue vs mechanical?
I'm curious as well on the fan, possibly unplug the heater fan while it's doing it (or the fuse for that circuit)? Could do same for starting circuit (remove the fuse) to rule that out as well? Possibly a bearing going bad in fan motor, or a mouse maybe made a home in there?
Dragcamaro is offline   Reply With Quote
Old 04-21-2020, 02:19 PM   #6
gmc396
Thanks for your comments and thoughts. The truck is stock so no electric cooling fans. I did stall the truck yesterday but the noise continued.
I looked in the fan shrouding for some pesky mice but everything is clear. I just turned on the ignition and ran the heater fan thru the 3 speeds but sounds normal.
Started the truck twice and normal. I'm going to drive to the PO now and see if it does it again
Old 04-21-2020, 04:45 PM   #7
toolboxchev
You have an electric fuel pump?
toolboxchev is offline   Reply With Quote
Old 04-21-2020, 05:34 PM   #8
Astro-Balls
Astro-Balls's Avatar
Would a broken clutch fan keep spinning and make noise?
1968 C20 Fleetside 396 4sp PS PB AC CST
https://www.youtube.com/watch?v=RWK8GgWD4uA
Astro-Balls is offline   Reply With Quote
Old 04-21-2020, 09:42 PM   #9
Boog
laying low
Boog's Avatar
Next time it does it raise the hood and go over to the right side and bump the starter with something hard. The starter may not be fully disengaged after the engine starts, still spinning.
Boog
69 Chevy stepside, 358/T350, 4.11 posi, 4.5/4 drop, rallys, poboy driver
primer is finer
91 Chevy sportside, Tahoe, Yukon & GMC Crewcab All GM..'nuff said.
Old 04-22-2020, 08:15 AM   #10
Mike C
Mike C's Avatar
Usually it is not that loud, but a harmonic balancer that has failed and the outer ring spins on the hub for a few seconds after the engine stops can make a racket.
44 Willys MB
52 M38A1
64 Corvette Coupe
68 Camaro 'vert LT1 & TH700
69 Z/28 355 12.6's @110
72 Jimmy 4WD 4spd 4" & 35's
02 GMC 2500HD 4x4 Duramax
Old 04-22-2020, 11:03 AM   #11
truckster
truckster's Avatar
Maybe post a video clip...
I have sworn upon the altar of God, eternal hostility against every form of tyranny over the mind of man. - Thomas Jefferson
truckster is offline   Reply With Quote
Old 04-22-2020, 03:45 PM   #12
gmc396
Thanks again for the comments. The harmonic balancer is an interesting possibility as I imagine that could be noisy when spinning. I started the truck and looked at the bottom pulleys by the harmonic balancer and all looked good with not wobble. I imagine once the rubber part of the balancer fails the pulleys would no longer run.Plus I can't see that continue to spin for what was a good 30 seconds.
I'm wondering if there was some type of short in the starter circuit that did not engage the starter gear but fed power to the starter motor.
I drive the truck daily so will keep my phone/camera handy so I'm ready next time it happens.
Old 04-22-2020, 04:06 PM   #13
HO455
Post Whore
HO455's Avatar
Got any family, relatives, friends, or neighbors who love a good practical joke?
RIP Bob Parks.
Old 04-22-2020, 04:27 PM   #14
Ol Blue K20
Proprietor of Dale's Corner
Ol Blue K20's Avatar
Power brake booster with a pin hole in the diaphragm might do it
Dale
XNGH ECV Sam Brannan 1004
R.I.P. 67ChevyRedneck
R.I.P. Grumpy Old Man
R.I.P. FleetsidePaul
Old 04-24-2020, 02:37 PM   #15
gmc396
Just for fun, posted a couple of pics
Old 04-24-2020, 04:37 PM   #16
Steeveedee
Who Changed This?
Steeveedee's Avatar
I like it! Are the crossed flags factory trim? They look cool on there, in any event.
~Steven
Simi Valley, CA
Steeveedee is offline   Reply With Quote
Old 04-24-2020, 11:51 PM   #17
gmc396
No, the cross flags for the 396 were added; couldn't resist. Right below the GMC emblem on the front fender it says V-8 and C2500.
Old 04-25-2020, 01:25 AM   #18
vitamin_c95
Auto or standard transmission? Just trying to think of other possibilities not mentioned.
1971 C20 Longhorn 350/350 "Conquistador"
vitamin_c95 is offline   Reply With Quote
Old 04-25-2020, 06:41 PM   #19
mikeshome
mikeshome's Avatar
he mentioned clutch somewhere in his post,
mikeshome is offline   Reply With Quote
Old 04-25-2020, 06:51 PM   #20
mrtoni
mrtoni is offline   Reply With Quote
Old 04-25-2020, 08:33 PM   #21
JT_Trucks87
JT_Trucks87's Avatar
Very cool truck! interested to see what the noise ends up being.
1987 V30 Silverado SRW 454/400 4x4 104k
1979 GMC C3500 Sierra Classic 3+3 454/4l80e
1971 K20 Cheyenne
http://67-72chevytrucks.com/vboard/s...d.php?t=804580
https://67-72chevytrucks.com/vboard/...d.php?t=837441
https://67-72chevytrucks.com/vboard/...92#post9355392
JT_Trucks87 is offline   Reply With Quote
Old 04-25-2020, 09:38 PM   #22
vitamin_c95
Wondering if the throw out bearing is going bad? Far fetch just thinking of other things to look for
Old 04-26-2020, 10:54 AM   #23
gmc396
It's a 4 speed "granny"
Old 04-26-2020, 06:41 PM   #24
Mike C
Mike C's Avatar
Nope, pulleys run just fine as they are attached to the hub. It is the outer ring that continues to spin when turning the engine off. It can move forward and backwards rubbing/grinding on the back of the pulleys or the timing cover.
44 Willys MB
52 M38A1
64 Corvette Coupe
Old 04-28-2020, 11:19 AM   #25
gmc396
Just so I understand, the outer ring of the harmonic balancer is the part with the timing mark on it. If that has broken loose, should I be able to turn it? I used a long wooden dowel rod and tried to move it with no luck. Could it have temporarily broken loose; that doesn't make sense to me. I've driven the truck a half dozen times since the noise and all has been normal.
Thanks for you help.
