04-21-2020, 03:50 PM | #1 |
New from South Orange County CA
Hello....
Just picked up a 1963 C20, 292 straight six, 4-speed. Can't wait to tear into it. |
04-21-2020, 07:24 PM | #2 |
Re: New from South Orange County CA
I like it!!!
I like 60-66's a lot, even though I have a 67 and a 68 Do the 60-66's have an option sheet inside the glove box??? |
04-21-2020, 07:57 PM | #3 |
04-21-2020, 09:21 PM | #4 | |
Moderator
It's called a SPID. Stands for SERVICE PARTS IDENTIFICATION.
04-21-2020, 10:06 PM | #5 |
60-66 Nut
Welcome to the forum
What are your plans for your '63?
04-22-2020, 09:24 AM | #6 |
It's Better With Nitro
Welcome from Chino Hills!
04-22-2020, 09:56 AM | #7 |
Wow, looks like you got a good one. Welcome.
04-22-2020, 11:27 AM | #8 |
Welcome! Looks like you have great starting platform. As asked before, what are your plans?
04-22-2020, 11:52 AM | #9 |
1965 Chevy C10, 2005 4.8L/4l60
Welcome!
Posted via Mobile Device |
04-22-2020, 01:04 PM | #10 |
Welcome! We can always use more 3/4 ton owners! Not to mentioned '63 3/4 tons still with original period hubcaps. What's great about original paint is no hidden body work. Wonder if it was Ivory or White? Paint code on kick plate tag. 292's are legendary, one of Chevy's best!
04-23-2020, 01:21 AM | #11 |
Nice truck. the garage is so typical of So. Cal.
04-26-2020, 04:29 PM | #12 |
Welcome. Plans?
04-27-2020, 11:57 AM | #13 |
Nice! Judging by the steering wheel paint, that's a low mileage truck.
Welcome from San Diego! If you decide to go the LS swap/modern transmission route, I want first dibs on the SM420 (original transmission).
Everybody has to believe in something. I believe I'll have another beer. |
04-27-2020, 12:06 PM | #14 |
Welcome to this incredible resource. Nice truck. My 1st truck was a C-10 '63 but had the 230 ci and three on the tree. Nice score Asshat.
'69 GMC C2500 Custom Camper, 8 1/2' bed, New GM 350, NP 435 Close Ratio 4spd. Trans., 3.73 Dana-60 open.Camper and Trailer wiring, PS, PB, AC, tach , three gas tanks, stereo speakers, 2nd owner, Work-Truck supreme. |
04-27-2020, 12:49 PM | #15 |
Looks like it was a desert truck, great floors. 292 was the power house back then.
1953 3100 261cu in, sm420, 3.55 torque tube, omaha orange 1964 GMC 1000 series,custom, 305E, sm420 |
04-27-2020, 01:23 PM | #16 |
Anybody notice the original full foam cloth seat?. Seat should have the red vinyl trim also. This reveals it has the custom comfort option.
04-30-2020, 10:25 AM | #17 |
Welcome, nice ride, BUT your handle name gave me pause to address you directly - Asshat......
http://s1299.photobucket.com/user/jb...23904108567829 |
04-30-2020, 12:15 PM | #18 |
Nice, I'm local. I built a 60 for a guy, they are simple trucks,
"Work hard, use your vacation days." 1970 C15 GMC Long Bed 1986 C20 Scottsdale 1983 K2500 Sierra Classic Suburban 6.2 Instagram: C10sofOC |
05-01-2020, 11:41 AM | #19 |
05-01-2020, 12:45 PM | #20 |
Hey everyone, thanks for the welocme.
Current plans... Got it running, just need to fix a few things: muffler better fuel inlet for carburetor get vacuum advance working rear turn signals not working - probably a bulb need to get some 8-lug, 16" wheels that take the modern radial tires need temp sender choke cable fix/attach upper radiator hose registration out of date bench seat needs uphosltery floor mats Need to do the wood slats in the bed - that's going to be an expensive, big job. Down the road, maybe change out the rear end so it will cruise down the freeway better. Possibly change the motor and trans - just not sure at this point in time. |
05-02-2020, 06:21 PM | #21 |
Big, yes but it doesn't have to be expensive. Depending on what you want and your wood working skills you can make your own bed wood. I bought some pine from Home Depot and spent about $120. I am going to paint it so I really didn't need anything fancy. Truck will be covered when parked.
"A man and his truck, what a beautiful thing" 65 Short Fleetside BBC 65 Long Fleetside 283 3 on the tree for now. my build thread http://www.67-72chevytrucks.com/vboa...d.php?t=259536 |
05-02-2020, 06:38 PM | #22 | |
Thanks! |
05-02-2020, 09:50 PM | #23 |
https://gmcpauls.com/47-72_BedWood_Info.htm
I used this for the measurements when my dad and I replaced the wood bed without buying a kit. It worked great!
Christian Carpenter 1963 C10 - Frankentruck 283, Muncie 3 speed with overdrive Overdrive wiring here1963-ish truck bed trailer - Half-Wit 1981 C10 - Penny 305, th350 --> Soon to be 350, Saginaw 4 speed 1995 Dodge Dakota Sport "I'll put it simple: if you're going hard enough left, you'll find yourself turning right." - Doc Hudson |
05-06-2020, 12:25 PM | #24 | |
Did you use a router to cut the grooves in the boards? What about hole locations? |
05-07-2020, 12:06 AM | #25 | |
We used a router, but it was a two man job as our routing table was tiny and my truck is also a long bed. If you are asking about the hole locations for the bolts that go through the wood to the frame, I didn't drill them. The previous owner used shorter bolts to just bolt the bed crossmembers to the frame without going through the wood. I think it has a cleaner look that way, but I'm not sure how the previous owner did it since I haven't pulled the bed off.
