04-21-2020, 04:34 PM | #1 |
Blazer rear quarters
Has anybody recently used a reproduction rear quarter on a Blazer? How was the fit and any problems. I know some of the earlier ones had issues. Thanks
04-22-2020, 08:18 AM | #2 |
Carpe manana
Re: Blazer rear quarters
Not sure this helps but here’s one that was partially reassembled using new rear quarters http://67-72chevytrucks.com/vboard/s...d.php?t=803514
Maybe the member who assembled can let you know how they fit.
1972 K5 CST Highlander Blazer: http://67-72chevytrucks.com/vboard/s...d.php?t=708547 1972 K20 Cheyenne Super: http://67-72chevytrucks.com/vboard/s...d.php?t=528308 Members met: ORANGBLAZ, 2003 silverado, MikeCofield, BB72CHEVKT, Duncan&Son, Sameyrasmea72, THENEWMEXICAN, HotRod C/10, brianthelion02, Sport/Truck, ryanroo, michael bustamante, Dirt's72, Already Gone, WestButteTruck, 57taskforce, Moreyel, painterljp, AASmedic, SoCoC10, Lumaestas, carbuff382, Chevyland |
04-23-2020, 03:53 PM | #3 |
I bought the quarters from Southern Kentucky Classics and they fit very nice! I was very happy with them.
04-23-2020, 04:17 PM | #4 |
I have one concern for the rear quarters - and that is the B-pillar/lower quarter body line.
The OEM panels are parallel with the rocker. On some of the aftermarket quarters - the b-pillar area slopes upward and is not parallel to the ground. This is not consistent for all panels though. Added photos for reference: One with highlighting - one without) Note the lower metal path is all aligned between front fender, outer rocker and the front part of the quarter. In some cases the front part of the quarter (red boxed area) angles upward. If you take an L-Square and lay it across the gap from rocker to rear quarter - this will be evident. Last edited by lks dcvn; 04-23-2020 at 04:24 PM. |
