Old 04-24-2020, 01:07 PM   #1
The Rocknrod
Moderator
The Rocknrod's Avatar
Engine Lift Tool
On the 60 to 66 C10's has anyone used the Mac's Tie-Downs PIVOT Engine Lift Plate with any success? I'm worried about the load leveling front to rear bar hitting the firewall as it did before it was painted.
I saw one on Texas metal that used straps. They used it side to side. FYI my grill, and grill support will not be on the truck when the engine is installed.
Old 04-24-2020, 02:03 PM   #2
vin63
It's Better With Nitro
vin63's Avatar
Re: Engine Lift Tool
The Macs leveler lift works pretty well. I also have a sling, but only use it side to side where the bar is parallel with the firewall. Will you have the transmission bolted to the block?
1963 C-10: Deluxe-optioned cab, shortbed, fleetside
Pontiac 462 ci, Kauffman D-Port alum. heads
4L80E, narrowed sheetmetal Ford 9-inch
Tubular front and rear suspension
Custom 6-piston front disc and 4-piston rear disc brakes
vin63 is offline   Reply With Quote
Old 04-24-2020, 02:46 PM   #3
msg
I ended up in a jam with this too. Solved it with a pad on the front and had to bottle jack it forward once I set it down to line up with the mounts. Having a different rig would have been great. Less worry.
Progress thread for my 66
http://67-72chevytrucks.com/vboard/s...d.php?t=623848
msg is offline   Reply With Quote
Old 04-24-2020, 03:09 PM   #4
The Rocknrod
Moderator
Yes I want to install the engine trans same time. How does it work with the trans bolted to the block? Does it hit the firewall?
That's one way. That's what I had before it was painted.
I think the side to side sling might work better? I don't know that's why I'm asking.
Old 04-24-2020, 11:10 PM   #5
nsb29
nsb29's Avatar
I used a load leveler with no problem had my chain’s much Shorter motor and trans
Hand made A/C vent manifolds for 64-66 trucks adapts any aftermarket A/C to OEM vent
nsb29 is offline   Reply With Quote
Old 04-25-2020, 07:01 AM   #6
The Rocknrod
Moderator
How short nsb29?
Old 04-25-2020, 04:22 PM   #7
nsb29
nsb29's Avatar
Just high enough to clear the top of the motor it was in LS 2
Old 04-25-2020, 05:09 PM   #8
Getter-Done
Getter-Done's Avatar
Here is one from Jegs with a lot of adjustment capabilities.
Link:https://www.jegs.com/i/OEMTOOLS/693/24831/10002/-1
The bolts could be removed to have the crank on the other end if needed.
Also chains could be set to different lengths
The early bird gets the worm,
85 Chevy K-20
Old 04-25-2020, 05:59 PM   #9
The Rocknrod
Moderator
Thanks, I have one similar to that one.
Old 04-25-2020, 06:52 PM   #10
nsb29
nsb29's Avatar
Mine came from cardboard freight
Old 04-25-2020, 07:08 PM   #11
vin63
vin63's Avatar
If you have the trans bolted to the block, the load leveler would work better. I still usually have a helper underneath to guide the tail of the transmission.
Old 04-25-2020, 08:46 PM   #12
The Rocknrod
Moderator
Load leveler, okay.
What would happen if I used the chain leveler only sideways? May work.
Old 04-26-2020, 12:04 AM   #13
msg
Load leveler, okay.
I had the same thought to avoid a run in with the firewall, but I dont think that you can tilt the engine trans unit downward like you would need to, just a left right tilt is all you would get.
Old 04-26-2020, 01:05 AM   #14
1971 GMC SHORTY
1971 GMC SHORTY's Avatar
Old Chain Works So much Better.. 🤣🤣🤣
1963 Impala
2021 Harley Road Glide
2003 ROAD KING 100th 124ci 6 Speed
145CI M/P Pro Street FXR
2002 FXDP
2006 Silverado 1500
Studio Teamsters / Mechanic
Retired GM Master Tech 20 Years
Retired Ford Tech 15 Years
1971 GMC SHORTY is offline   Reply With Quote
Old 04-26-2020, 09:37 AM   #15
vin63
vin63's Avatar
Load leveler, okay.
You would only be able to adjust the level side to side, not front to back.
The carb plate leveler by Mac would work the best of the ones you mentioned since you'll need to level the engine/trans front to back due to the weight of the transmission on the backside of the block. I would still have a helper underneath to help guide the tailshaft of the transmission.
Old 04-26-2020, 10:52 AM   #16
The Rocknrod
Moderator
Even with the front end off?
Old 04-26-2020, 11:16 AM   #17
bigmoe
bigmoe's Avatar
I did mine as pictured but had trouble with straps and bolts hitting the fire wall. We managed to get it in but if I did it again I'd hook the back ones to the side of the heads.
bigmoe is offline   Reply With Quote
