Old 04-25-2020, 12:16 AM   #1
bean
Rust around windshield
Just ordered the repair panel to fix the last rusty area on my truck. Does anyone have some pics from when they did this repair? Thanks
bean is offline   Reply With Quote
Old 04-25-2020, 12:18 AM   #2
Jcfcamaro
Jcfcamaro's Avatar
Re: Rust around windshield
Inside of cab?
Jcfcamaro is offline   Reply With Quote
Old 04-25-2020, 12:20 AM   #3
toolboxchev
Yea, pics of your truck and the area would be necessary to get things moving for you.
toolboxchev is offline   Reply With Quote
Old 04-25-2020, 12:27 AM   #4
LockDoc
The Older Generation
LockDoc's Avatar
Here is where my rust was and how I fixed it. Cut out the rusty area, welded in new metal and ground it down smooth. It would basically work the same no matter where the rust was.
LockDoc
Leon
Old 04-25-2020, 10:40 AM   #5
bean
I am replacing the inner roof panel. Does anyone have some pics of when they did it?
Old 04-25-2020, 11:14 AM   #6
Jcfcamaro
Jcfcamaro's Avatar
I did. I also bought the upper patch panel behind the sun visors and only used what I needed to get back to good metal. So from the pinch weld up it was about 3in up. I'll try to post pictures but for some reason it wont let me from my gallery only by taking new ones with the camera option.
Old 04-25-2020, 11:16 AM   #7
Jcfcamaro
Jcfcamaro's Avatar
I would only replace what you have too,unless its really bad.
Old 04-25-2020, 11:19 AM   #8
HO455
Post Whore
HO455's Avatar
If you do a search for "roof rust repair" you will find lots of threads on the subject. Many by people who may no longer be active on the board to respond to your thread. Remember to click the 67-72 button.
Good reading.
RIP Bob Parks.
Old 04-25-2020, 11:24 AM   #9
57taskforce
All about them K’s
57taskforce's Avatar
Yep that’s the best advice for rust repair in my opinion. Just because you have a whole patch panel doesn’t mean you necessarily need to use it.
Tyler
'72 K20 Cheyenne http://67-72chevytrucks.com/vboard/s...d.php?t=662879
‘69 K10 SWB http://67-72chevytrucks.com/vboard/s...d.php?t=805206
'98 Silverado LT K2500HD ECLB Vortec 454/4l80E: 6" lift 315/75/16's
‘87 IROC-Z all original 50K mile survivor TPI 305 IROC Blue
‘10 Camaro 2SS/RS Aqua Blue Metallic #93 -version 2.0
57taskforce is offline   Reply With Quote
Old 04-25-2020, 09:42 PM   #10
bean
Thanks guys definitely will only replace what's needed..
Old 04-26-2020, 08:56 AM   #11
Leonard1
Leonard1's Avatar
How do you guys weld that in without warping it? I would think that it would be very distorted without planishing the weld, and you need access to the back for that.
Leonard1 is offline   Reply With Quote
Old 04-26-2020, 09:29 AM   #12
Daves70
Daves70's Avatar
I've always stitch welded, VERY slowly. Small short welds a fair distance apart giving lots of time for the metal to cool. This idea is to not get the metal hot. Some guys blow compressed air on the weld after to cool it off. I've never had luck with that. Eventually you have it all welded in without distortion. The next tricky part is grinding it smooth without heating it up. Again going really slow is the trick. I find ,I have more trouble with the grinding part than the welding. The more you do ,the better you'll get at it. Good luck.
Daves70 is offline   Reply With Quote
Old 05-04-2020, 05:03 PM   #13
Dukk
To tag on to this - I recently looked a one that was ok on the floor but there was an outside hole above the windshield, a corresponding one inside above the windshield and it was pretty rotten above the driver door opening.
Looking in the LMC catalog, I see an interior patch where the sunvisors are, and an exterior strip above the windshield, but don't see anything for above the doors. Does someone make a patch for this area?
Dukk is offline   Reply With Quote
Old 05-04-2020, 06:30 PM   #14
57taskforce
All about them K’s
If the floors are good I’d clip the roof off of another truck. Honestly it’s easier than to start digging into the roof rust. What you see on the outside is only a small portion of what’s really there most of the time.
Tyler
Old 05-04-2020, 11:26 PM   #15
Southpaw69
When I did mine there were some spots that required me to just make little patches with spare metal. If it's not in a corner or something odd, it's not too bad to just make em.
Southpaw69 is offline   Reply With Quote
