Fuel Pump issues
Had some body work done on my truck so its been out of commission for about 5 or 6 months. Was running/cranking fine. Now not getting gas to carb, checked a few things and finally decided to replace mechanical fuel pump. Still not getting gas to carb, any ideas? I have line disconnected now from carb and filter and its still now pumping fuel.
![]() Join Date: Jul 2015
Re: Fuel Pump issues
First what year is your truck? 72's 71's and even earlier had the Vap Canister system first part of the Emissions Control.
Then you will have to start at the tank and check first your pickup, cleanliness of tank, and work from there to the pump. Lines can clog, rust out. Make sure your able to get flow. Maybe use an air gun to blow through the lines. |
Be sure there is sufficient gas in the tank. Check the fuel line between tank and fuel pump. Check for kinks and disconnects.. Replace any missing or suspect rubber lines.. Be sure all connections are tight and leak proof.. Replace all fuel filters..
#4 | |
#5 | |
#6 | |
Post Whore
![]() Join Date: Feb 2016
It is possible that the needle has become fused to the seat of the float valve inside the bowl of the carburetor. If you have fuel pressure at the carburetor fuel inlet it is likely that is your problem. Although some carburetors have a filter in the fuel inlet they usually fail slowly over time with reduced engine performance being the symptom.
Thanks to Bob and Jeanie and everyone else at Superior Performance for all their great help. ![]() RIP Bob Parks. 1967 Burban (the WMB),1988 S10 Blazer (the Stink10 II),1969 GTO (the Goat), 1970 Javelin, 1952 F2 Ford OHC six 4X4, 29 Model A, 72 Firebird (the DBP Bird). 85 Alfa Romeo If it breaks I didn't want it in the first place The WMB repair thread http://67-72chevytrucks.com/vboard/s...d.php?t=698377 |
