Old 12-10-2003, 05:57 PM   #1
cheatham
I need a brake!
cheatham's Avatar
Heater Control
I got the wiper motor swapped out no problem. Also replaced the defrost hosing. One was ripped all apart, and the other was completely clogged with leaves- wish I had done that a long time ago. My motor was a three wire connector, btw.
Now that I got that done, today I broke a second lever off of my heater control. I am wonering if I should replace the levers, or if I should just get a whole 'nother heater control. I will ask on the parts board, but don't have the money yet. If the levers aren't easy to switch out I guess I should just get a new box.
JP
MEMBER OF THE DISCS UP FRONT CLUB
1971 Chevy C10
cheatham is offline   Reply With Quote
Old 12-10-2003, 06:08 PM   #2
CPNE
Resident Curmudgeon
CPNE's Avatar
Non ac heater control levers are easy to replace and the replacement kit uses a better quality steel than the old pot metal ones. Get the kit and replace all 3 levers at the same time!
Currently on or near the homestead:
67 Chevy SWB 2WD stepside 350/3 on tree (Pat's)
67 GMC SWB 2WD Fleet 402/auto (Brian's under construction)
67 Chevy 3/4 ton 2WD 402/auto (Business Hauler)
67 Chevy 1 ton dually 2WD 396/4 speed (Former business hauler, Needs TLC)
68 Chevy 1/2 ton Suburban 2WD 250 six/3 on tree (Brian's Needs TLC)
70 Chevy 3/4 ton 4WD 350/4 speed (Pat's - Disguised as a 68 GMC)
71 Chevy SWB stepside (Crushed by tree - parts donor)
72 Chevy 3/4 ton 4WD (Parts donor)
72 Chevy 3/4 ton 4WD Suburban (Parts Donor)
72 GMC 3/4 ton 4WD 292 six/4 speed (Mine - Disguised as a 67 GMC)
81 GMC 4WD Dually Dump Body 350/4 speed (Business Hauler)
82 Camaro Z/28 355/Super T-10 (Pat's toy)
93 Caprice 9C1 (Brian's Cop Car)
02 Toyota Camry (Reliable but a souless steel and plastic hulk)
2011 2SS RS Camaro M6 Factory Hurst Shifter
Maybe I need to sell some of this crap
Yet another Bozo with a sawz-all
CPNE is offline   Reply With Quote
Old 12-10-2003, 06:44 PM   #3
jhow66
jhow66's Avatar
Also free up your cables before adding new levers--WD40
56 Chevy Bel-Air 2dr. HT (purchased new)
71 Chevy Cheyenne SWB PU (502HO)
65 GMC short bed step--work in progress and my gofer
jhow66 is offline   Reply With Quote
Old 12-10-2003, 07:01 PM   #4
cheatham
I need a brake!
cheatham's Avatar
Good. I thought I had heard the controls were somewhat of a PITA to replace, apparently that is AC units, though. Thanks for the replies.
JP
1971 Chevy C10
Old 12-11-2003, 12:47 AM   #5
PanelDeland
I am a Referee of life.
PanelDeland's Avatar
It took maybe an hour to remove repair and replace the control unit on mine.I spaced it out over a couple of days so I could paint the unit.I had a cable frozen solid.I put it in the parts washer for a day or two then in a drain pan of oil for a couple of days.I lube it ocassionally but it's been good for 5 years.
The 47-present Chevrolet and GMC Truck Message Board Network,it's owners,moderators,members,and associates of any type should not be held responsible for my opinion.
You can't fix stupid,not even with duct tape.
"My appearance is due to the fact that "GOD" does punish you for having too much fun!"
Barrett-Jackson has perfected alchemy,they make rust into gold!
"You can lead a horse to water but you can't saddle a duck"
"Cleverly disguised as a 'Responsible Adult'
"Sometimes your Knight in shining armor is just a retard in tinfoil"
PanelDeland is offline   Reply With Quote
Old 12-11-2003, 08:32 PM   #6
Pilgrim
Controls can be a PITA, but patience, WD40, and Samuel Adams ease the pain. New is well worth it.
Bob
68 C20 Camper Special
Pilgrim is offline   Reply With Quote
Old 12-12-2003, 01:42 AM   #7
dinnut
dinnut's Avatar
my 72's heater doesnt seem to work. the fan lever in the middle of the 3 levers for a non ac truck broke off i think. but before i bought it. who sells the replacement kit?
70 longbed
496/th400/Ford 9"
dinnut is offline   Reply With Quote
Old 12-12-2003, 01:43 AM   #8
lukecp
Formerly yellow72custom
lukecp's Avatar
I bought the kit...not too bad for $20 and was really easy to install
'72 Chevy C10 Mild 350/TH350/3.07. Ochre/White. Old high school ride.
'70 GMC C2500 '62 327 4bbl/SM465/4.56-geared Dana 60. White/White. Project or parts truck.
'97 Saturn SL DD. 1.9/5-speed. 40+ highway mpg
lukecp is offline   Reply With Quote
Old 12-12-2003, 02:02 AM   #9
sdredneck
The Crazy Kracka
LMC Truck sells just about anything you need for these trucks. Plus GMC Pauls seems to have a pretty complete section but I can't vouch for them yet.
sdredneck is offline   Reply With Quote
Old 12-13-2003, 03:47 AM   #10
jimfulco
I saw one in a wrecking yard once with a unique heater control. Each broken lever had a flattened .357 Magnum case slipped through the slot & onto the stub. All 3 worked, although a bit stiffly.
jimfulco is offline   Reply With Quote
