Old 04-25-2020, 11:12 PM   #1
kmswi
Which axle is better Dorman or Motive brands
I need to replace an axle shaft that is bent,which is a better brand ? Its for a 76 gmc 1/2 ton 2wd. Daily driver. had an issue with the drum getting hot,swapped side to side,no difference with the drum,but the drum on backwards and showed up that way.
kmswi is offline   Reply With Quote
Old 04-27-2020, 12:37 PM   #2
hatzie
Moderator
hatzie's Avatar
Re: Which axle is better Dorman or Motive brands
Dorman has gone to the dogs if they were ever OK.
If you want to hear some coments about them watch Eric from South Main Auto on Youtube.
1959 M35A2 LDT465-1D SOLD
1967 Dodge W200 B383, NP420/NP201 SOLD
1969 Dodge Polara 500 B383, A833 SOLD
1972 Ford F250 FE390, NP435/NP205 SOLD
1976 Chevy K20, 6.5L, NV4500/NP208 SOLD
1986 M1008 CUCV SOLD
2000 GMC C2500, TD6.5L, NV4500
2005 Chevy Silverado LS 2500HD 6.0L 4L80E/NP263
2009 Impala SS LS4 V8
RTFM... GM Parts Books, GM Schematics, GM service manuals, and GM training materials...Please include at least the year and model in your threads. It'll be easier to answer your questions.
And please let us know if and how your repairs were successful.
Old 04-27-2020, 08:25 PM   #3
bhc41051
bhc41051's Avatar
As far as parts go my strategy is
1. New Old Stock (If available and price is bearable.)
2 Look for good used. www.carpart.com, craigslist, Parts board on this site.
3 Look harder.
4 If all else fails, Chinese junk
bhc41051 is offline   Reply With Quote
Old 04-27-2020, 09:44 PM   #4
TrailerTrash
TrailerTrash's Avatar
I bought a Dorman axle shaft last summer for my 77 half ton 2wd. I needed one and Advance Auto could get it in the next day. I went over it meticulously before I paid for it and took it home. I counted splines, checked the bolt pattern, seal fitment, bearing fitment, ect. It checked out just fine and has been good so far.
- When the Reaper makes his deal, trust in your steel -
'77 C10 350/350 2/4 drop and a mild street engine
TrailerTrash is offline   Reply With Quote
Old 04-28-2020, 08:23 AM   #5
JMac11
JMac11's Avatar
Just installed a Dorman, no worries
JMac11 is offline   Reply With Quote
Old 04-29-2020, 11:19 AM   #6
kmswi
I just got a dorman from advance also, the boss on the wheel end is not machined correctly, the drum will go on but the wheel will not seat correctly, i need to grind it down ? I;ve tried different wheels, no difference.
Old 04-30-2020, 08:47 AM   #7
hatzie
Moderator
hatzie's Avatar
Unfortunately that's the kinda stuff that I've run into with Dorman.
Hit or miss on the quality control.
GM wheels are hub centric so you need that hub to be machined concentric with the centerline of the splines and the bearing contact surface as well as being the proper diameter. I'd ship it back and buy something else.
