04-26-2020, 10:08 AM | #1 |
WTB ALT Bracket
I need this one its longer than what I have gets the altenator further from the V-cover
Grand Theft Auto https://67-72chevytrucks.com/vboard/...d.php?t=855961 Doc & Kim build http://67-72chevytrucks.com/vboard/s...d.php?t=722288 I am from the desert http://67-72chevytrucks.com/vboard/s...d.php?t=650332 basket case build SOLD http://67-72chevytrucks.com/vboard/s...d.php?t=648557 |
04-26-2020, 10:13 AM | #2 |
Re: WTB ALT Bracket
I'll check for that in my garage in about ten minutes, might have it not sure, I find things I don't remember having, lol, alright give me fifteen minutes, I'll get back to you.
Nick |
04-26-2020, 10:20 AM | #3 |
Re: WTB ALT Bracket
i do he same thing ...thats funny if you find can you give me a measurement please
04-26-2020, 10:33 AM | #4 |
Re: WTB ALT Bracket
just took a couple pics of what i have this may not be easy to find note the bend in mine put the towel under it so you can see the bend clearly
04-26-2020, 10:39 AM | #5 |
Re: WTB ALT Bracket
I wonder if i attache a longer bracket to the water pump will I get it to line up and not loose the additional reach im looking for
04-26-2020, 10:42 AM | #6 |
Re: WTB ALT Bracket
If you don't mind , I sent you a private message with my cell # , give me a call I can send you a pic, also how should I measure this.
Nick |
04-26-2020, 10:42 AM | #7 |
Re: WTB ALT Bracket
I believe I have one like that, I will look here shortly.
04-26-2020, 10:44 AM | #8 | |
Re: WTB ALT Bracket
thank you
04-26-2020, 10:47 AM | #9 |
Re: WTB ALT Bracket
I measured it with a flex ruler going around the top, 17 inches . It looks the same,but looks shorter
04-26-2020, 10:50 AM | #10 |
Re: WTB ALT Bracket
your PM box is full i tried to send you a PM
04-26-2020, 10:54 AM | #11 |
Re: WTB ALT Bracket
Grand Theft Auto https://67-72chevytrucks.com/vboard/...d.php?t=855961 Doc & Kim build http://67-72chevytrucks.com/vboard/s...d.php?t=722288 I am from the desert http://67-72chevytrucks.com/vboard/s...d.php?t=650332 basket case build SOLD http://67-72chevytrucks.com/vboard/s...d.php?t=648557 Last edited by zicc1835; 04-26-2020 at 10:54 AM. Reason: more |
04-26-2020, 10:55 AM | #12 |
Re: WTB ALT Bracket
TY im going to measure mine
04-26-2020, 11:27 AM | #13 |
Re: WTB ALT Bracket
I believe what you're looking for is the 72 only alt bracket like the top one in the pic.
The shorter version, pictured on the bottom is the earlier style like my 70 had before I replaced it with the 72 style. |
04-26-2020, 11:48 AM | #14 |
Re: WTB ALT Bracket
Here is what I have
04-26-2020, 01:39 PM | #15 |
Re: WTB ALT Bracket
I bought that exact alternator bracket from performance online. Not OEM, but it works for me.
https://www.performanceonline.com/Ch...acket-kit-SWP/
1968 GMC C2500 Long Bed Fleetside |
04-26-2020, 08:49 PM | #16 |
Re: WTB ALT Bracket
does the 72 style have a offset away from the block .... I think NGN has one of those i can drive to get it thank you
04-26-2020, 08:50 PM | #17 |
Re: WTB ALT Bracket
thanks for looking Im going to see if the one NGN has will fit i can drive to his place
04-26-2020, 09:11 PM | #18 |
Re: WTB ALT Bracket
Not sure I understand your question completely, but I think you're asking if the 72 style bracket will have the same offset as the chrome bracket you have pictured above. If that is correct, then yes, the 72 style bracket will have the same offset and will install the same way as your current chrome bracket. The 72 bracket has a longer slot which will allow you to use a longer belt, therefore moving the alternator away from the valve cover for increased clearance for taller/aftermarket valve covers.
04-26-2020, 09:46 PM | #19 |
Re: WTB ALT Bracket
I thought it was just me I only have enough clearance between the valve cover and alternator for a piece of paper . the alternator is at max adjustment took a lot of trips back and forth to the parts store to find a belt to force on
04-26-2020, 10:21 PM | #20 |
Re: WTB ALT Bracket
You are not alone. I had to do the same thing prior to installing the 72 style upper bracket. Plenty of adjustment now.
04-26-2020, 10:28 PM | #21 | |
Re: WTB ALT Bracket
It worked for me .
1967 Factory short bed - Old school '71 - 350 / 4bolt / 487 heads / Edelbrock C3BX Muncie M-22 4 speed / Hurst Comp plus Factory 12 bolt posi 3.73 / 255-70-15 Smoothed firewall / Factory cowl induction Power disc brakes / power steering / 3.5-5" drop |
04-27-2020, 05:42 AM | #22 | |
Re: WTB ALT Bracket
thanks again......stay healthy
04-30-2020, 08:46 PM | #23 |
Re: WTB ALT Bracket
Grumpy do you have a part # for the belt you are using I have struck out 4 times at advanced auto.....
thanks Jess
05-12-2020, 08:07 AM | #24 |
Re: WTB ALT Bracket
after a recent trip to Tractor Supply (NG) and a few to Napa here is Part# 7530 and what I came up with that worked for me... as you can see there is least one inch clearance between the valve cover and alternator and relatively easy to get it over the pulleys with some adjustment left ...and many thanks to NGN
Grand Theft Auto https://67-72chevytrucks.com/vboard/...d.php?t=855961 Doc & Kim build http://67-72chevytrucks.com/vboard/s...d.php?t=722288 I am from the desert http://67-72chevytrucks.com/vboard/s...d.php?t=650332 basket case build SOLD http://67-72chevytrucks.com/vboard/s...d.php?t=648557 Last edited by zicc1835; 05-12-2020 at 08:07 AM. Reason: more |
