Old 04-26-2020, 03:37 PM   #1
ltdmstr
ltdmstr's Avatar
Need trailing arm measurements
I have the back half of my '68 down to the frame to clean it up and add new parts. Unfortunately, my trailing arms are total junk. The middle portion are rusted all the way through and the two halves are spread apart probably 3/4" or so. I haven't been able to find any good used ones, and the aftermarket replacements I've seen looked like crap for $500. So I'm making my own. Does anyone have actual drawings showing the dimensions for these? My main concerns are the locations of the holes for the spring mounting bolts and u-bolts for the rear axle. And also the angle of the kick-up in the rear where the axle mounts. My stock arms are too messed up for me to measure accurately, and I'd like to get this right the first time. Thanks.
ltdmstr is offline   Reply With Quote
Old 04-26-2020, 05:16 PM   #2
AussieinNC
Moderator
AussieinNC's Avatar
Re: Need trailing arm measurements
Try looking through the for sale ads on here for one or become a supporting member and post a want to buy ad.
There are also several aftermarket suppliers of these arms and several vendors offer direct replacement factory style arms...
Family and country before all others...
2006 Chevy Silverado (Daily Driver)
2012 Chevy Equinox
AussieinNC is offline   Reply With Quote
Old 04-26-2020, 05:26 PM   #3
bigmac73
bigmac73's Avatar
https://www.classicindustries.com/sh...railing%20Arms
Mike
72 C-10 Cheyenne off frame resto and Upgraded to 4 wheel disk, Tilt, Dakota Digital Dash / Rear slider.
421 SBC / TH350 3000RPM Stall
Progression Ignition /Holley 750 DP/3:73 gear Eaton Limited Slip unit / 2 1/2 exhaust glasspacks
bigmac73 is offline   Reply With Quote
Old 04-26-2020, 06:33 PM   #4
ltdmstr
ltdmstr's Avatar
Yeah, I'm pretty much set on making my own. Hoping someone has the dimensions.
