Old 04-28-2020, 01:18 PM   #1
68Blu
New engine smell???
Hey guys, just dropped a new 350 in the 68, now I notice the smell of burning oil after driving for about 15 mins. There are no leaks/ puddles after driving or sitting over night. It also doesn’t appear to be the heater core as it’s also isn’t leaking and there are no melted wires. Any ideas? Thanks
68Blu is offline   Reply With Quote
Old 04-28-2020, 01:24 PM   #2
Ol Blue K20
Proprietor of Dale's Corner
Ol Blue K20's Avatar
Re: New engine smell???
Are you smelling oil or paint curing and burning off?
Dale
XNGH ECV Sam Brannan 1004
R.I.P. 67ChevyRedneck
R.I.P. Grumpy Old Man
R.I.P. FleetsidePaul
Old 04-28-2020, 01:46 PM   #3
Willys_MB
Willys_MB's Avatar
Did you break in the cam and change the oil before driving it?
1968 GMC C2500 Long Bed Fleetside
Willys_MB is offline   Reply With Quote
Old 04-28-2020, 02:44 PM   #4
68Blu
Brake in was done as per GM instructions. It’s oil.
Old 04-28-2020, 02:56 PM   #5
sick472
sick472's Avatar
PCV working correcty?
Strong oil smell under the hood or out the exhaust?
It's not belt rubber smell?
A slight leak can run onto the headers/maniflods and burn off without any drips or puddles (so can antifreeze leaks).
Is it brake fluid on the discs/drums?
Ol Blue hit on something that always takes me by surprise...when a fresh motor starts up and starts smoking the paint (or oil residues from assembly) of the manifolds.
He who is without oil shall throw the first rod. Compressions 8.7:1
1972 C10
1976 C10 (parts truck)
1985 K20
sick472 is offline   Reply With Quote
Old 04-28-2020, 02:58 PM   #6
Willys_MB
Willys_MB's Avatar
How many miles since you changed the oil? I recently did my first break in and had a similar issue that went away after a second oil change.
Old 04-28-2020, 02:59 PM   #7
geezer#99
geezer#99's Avatar
Look on the back of the intake. Could be china wall gasket or oil pressure fitting. Any leaks there don’t show up on the floor. Just coats the top of the trans and underside of the truck.
geezer#99 is online now   Reply With Quote
Old 04-28-2020, 03:02 PM   #8
hamjet
hamjet's Avatar
or dripping on the exhaust pipe..
Thanks, Joe..
1969 C/10, 348 C.I., 3X2 bbl. V8, 2004r , LWB.
hamjet is offline   Reply With Quote
Old 04-28-2020, 04:08 PM   #9
zosoppp
it might also be leaking/seeping valve cover gaskets, especially with the older flange bolted valve covers. that would leak out onto the manifolds and burn and likely not make it to the floor for quite a while.
1970 C10 LWB 350SBC, SM330 Muncie (not saginaw SM326) (on tree), 3.07 open (assumed), PS, PB, Idiot lights
zosoppp is online now   Reply With Quote
Old 04-29-2020, 07:48 PM   #10
bigmac73
bigmac73's Avatar
Best thing is dust with baby powder and run engine and see if you see a wet spot or oil trail
Mike
72 C-10 Cheyenne off frame resto and Upgraded to 4 wheel disk, Tilt, Dakota Digital Dash / Rear slider.
421 SBC / TH350 3000RPM Stall
Progression Ignition /Holley 750 DP/3:73 gear Eaton Limited Slip unit / 2 1/2 exhaust glasspacks
bigmac73 is offline   Reply With Quote
Old 04-30-2020, 11:56 AM   #11
68Blu
Thanks guys! I will checking all of these things in the coming days and will keep you posted ��
Old 05-01-2020, 09:13 AM   #12
fdbdw
fdbdw's Avatar
Did you by chance put in any new exhaust parts?I have had burning smell from new mufflers and headers in the past. Sometimes they are coated with an oil for storage , then it burns off in the first couple warm ups.
fdbdw is offline   Reply With Quote
Old 05-04-2020, 09:14 PM   #13
68Blu
Well, guys the mystery continues. I checked your recommendations and nothing. Thanks again
Old 05-04-2020, 10:49 PM   #14
Steeveedee
Who Changed This?
Steeveedee's Avatar
Central coast- are you around Ventura somewhere thereabouts? Maybe there's somebody that could come by and take a look-see. Plenty of board members in California. Just saying. I'm about 40 miles from you. Maybe I can make an excuse to go to a store in Ventura if I can evade the popo.
~Steven
Simi Valley, CA
Steeveedee is offline   Reply With Quote
Old 05-05-2020, 12:21 AM   #15
bcfishon
Has to be an external leak somewhere,i would drive it till it smells and pull into dark shop with flashlight to inspect,smoke shows up better in the dark. Only so many places it could leak,intake,distributor,valvecovers,fuelpump,oil pressure,timing chain/oil pan or the rear seal,God forbid you have a leaky oil galley plug.
bcfishon is offline   Reply With Quote
Old 05-05-2020, 12:42 AM   #16
geezer#99
geezer#99's Avatar
Could be internal too.
Poorly installed intake gasket that’s not sealing and oil is being pulled up from the lifter valley.
Old 05-05-2020, 09:11 PM   #17
Corts60
Just here to tinker
Corts60's Avatar
If you can't find any external leaks, pull plugs and look to see if any cylinders are oil soaked. If you find one, perform a leak down test of that cylinder to see what exactly failed.
Old 05-06-2020, 09:07 PM   #18
68Blu
I’m not getting emails from this site anymore, sorry for the late response. I’ll try to start checking in more. I’m actually over 1.5 hours from Ventura, Steeveedee- thanks for the offer though. I’ll keep looking and try your suggestions but it may be a week or 2... Thanks again everyone.
Old 05-08-2020, 05:29 PM   #19
bcfishon
I would think a internal leak would let stink go out the tailpipe unless you have some serious exhaust leakage but one never knows how another rig blows. Do not forget it takes a little bit for new rings to seat and sometimes especially with high oil pressure systems oil can make it past the rings and give off a unburnt petroleum smell from the exhaust stroke,I love that smell but this sounds different,good luck.
Old 06-17-2020, 10:39 PM   #20
68Blu
Found it. Not the engine but the transmission. New tranny and we’re off. Thanks everyone for the suggestions.
Old 06-18-2020, 12:22 AM   #21
Stocker
20' Daredevil (Ret)
Stocker's Avatar
Sure didn't see that one coming! Glad you found it & got it fixed!
- Mike -
1972 K20 LWB 350/350/205
RIP El Jay
Stocker is offline   Reply With Quote
Old 06-18-2020, 09:09 AM   #22
BigBird05
Just before you posted the trans, I was thinking vacuum modulator. It doesn't happen often, but when it does, it's hard to find.
BigBird05 is offline   Reply With Quote
