Old 04-28-2020, 09:04 PM   #1
03BlkZ
Steering column issue
Hello, I am currently rebuilding my 3 speed non tilt column from my 70 C10 and I am unable to get the lower bushing all the way in. My stack up is right based off my pictures when I took it apart but now it will not go all the way in. Any ideas?
03BlkZ is offline   Reply With Quote
Old 04-28-2020, 09:39 PM   #2
70shortfleet
70shortfleet's Avatar
Re: Steering column issue
not suppose to go in all the way, you might have the last piece in backwards, I can`t see the end of that piece
70shortfleet is offline   Reply With Quote
Old 04-28-2020, 09:44 PM   #3
03BlkZ
You are correct. I had the lower bushing in backwards. I'm an idiot.
Old 04-28-2020, 11:16 PM   #4
maverickmk
maverickmk's Avatar
Want to rebuild another one?
Die with memories, not dreams.
Not to brag, but I don't need alcohol to make really bad decisions.
1969 GMC Short Step Side
maverickmk is offline   Reply With Quote
Old 04-29-2020, 08:22 AM   #5
03BlkZ
My next question is where does the plastic thrust washer and rubber ring go? I missed it in my picture taking when I disassembled it. Epic failure on my part I know.
Old 04-29-2020, 09:00 PM   #6
03BlkZ
Never mind. I figured it out when I assembled it.
Old 04-30-2020, 05:31 PM   #7
toolboxchev
No everyone here has voted, we know its not you in the member pic. When are you letting go of that one?
toolboxchev is offline   Reply With Quote
