![]() Join Date: Nov 2014
Help with Tachometer dash
Looking for some help in completing a tachometer dash. I already have the tins and lens. Lots of extra gauges too. I think all I need is the tachometer, HEI wiring harness and printed circuit.
Anything else I’d need? Where should I buy the parts I need? Anyone sell a tachometer that works with HEI ignition?
07' Extcab Silverado Z71 Silver Birch, 5.3L HO 71' Cheyenne C10 Hugger Orange on Saddle SWB Besides these two, too Many to count |
#2 | |
The Older Generation
Re: Help with Tachometer dash
I am also i the process of putting together one standard tach cluster and one tach/vac cluster. I have everything I need except one tachometer. I was going to order one from Classic Parts ( https://www.classicparts.com/1967-19...departments/7/ ) but it says they are out of stock on them. I don't know if there is more than one manufacturer or not. I notice that some of the vendors list them as Dynacorn brand and some don't list a manufacurer. I don't usually order from LMC but they show them in stock. It looks like working with HEI is a crap shoot. One vendor says if you are going to use the aftermarket tach's with HEI be sure you have an OEM GM HEI or at least an OEM ignition module in the distributor. LockDoc
Leon Locksmith, Specializing In Antique Trucks, Automobiles, & Motorcycles (My Dually Pickup Project Thread) http://67-72chevytrucks.com/vboard/s...d.php?t=829820 - Last edited by LockDoc; 05-05-2020 at 11:06 PM. |
Old member
I just finished this one last night. Stock Tach dash. New LED bulbs and lens with Bezel. Painted all the needles to match and cleaned everything up good.
I have another one I will do as soon as my parts get here. ![]()
1971 LWB Custom, 6.0LS & 4L80E, Speedhut.com GPS speedometer & gauges with A/C. 20" Boss 338's Grey wheels 4 wheel disc brakes. My Driver Seeing the USA in a 71 ![]() Upstate SC GM Truck Club 2013,14 and 2016 Hot Rod Pour Tour http://upstategmtrucks.com/ Get out and drive the truck this summer and have some fun! It sucks not being able to hear! LWB trucks rule, if you don't think so measure your SWB! After talking to tech support at Air Lift I have found out that the kit I need is 60811. Per the measurements I gave them. Ride height of truck inside spring and inside diameter of springs. |
#4 | |
Thanks for your input.
Cluster King
![]() Join Date: Nov 2012
Please contact me with your cluster needs.
I sell used parts in all conditions. Do repair and restorations. I am also a Counterpart dealer. Anything you see (gauge cluster related only) in the truckandcarshop.com catalog, I can save you money on any cluster parts you need. I also offer tech support for those who need help Tom
Contact me on all of your gauge cluster needs. I specialize in restoration, repair and parts sales for 67-72 Chevy and GMC trucks. email me at tbonegarris@yahoo.com I am also a dealer for Counterpart for gauge cluster parts only. Also see my facebook page, CG&C |
#6 | |
Cluster King
I sell Counterpart brand tachs and never had one failure in 7 years. They do not work on multi spark discharge ignition systems.
#7 | |
Hi Tom, I'm not a tach guru myself, but this has been posted by a well respected vendor on here many times. http://67-72chevytrucks.com/vboard/s...d.php?t=698386 Post #4 Also this thread. http://67-72chevytrucks.com/vboard/s...=795746&page=2 Post #27, and you seemed to agree with him in post #28. Let me know, I just don't want to post erroneous info. Thanks, LockDoc
Leon Locksmith, Specializing In Antique Trucks, Automobiles, & Motorcycles (My Dually Pickup Project Thread) http://67-72chevytrucks.com/vboard/s...d.php?t=829820 - Last edited by LockDoc; 05-05-2020 at 10:17 PM. |
#8 | |
Cluster King
I would be the first to agree that using high quality ign parts is the only way to go. I have taken HEI distributor's out of trash cans that work better than any China distributor. To date after 7 yrs and I would roughly guess 300 aftermarket tachs, not one failure from using HEI. I don't pretend to know everything, but I could be an advocate for aftermarket tachs. The question has never been "will my tach work if I use a junk module?". From my end, I have no idea what these guys are plugging that 12g brown wire to. I know what not to hook it to. This has been debated forever but from my side, nothing to worry about.
#9 | |
Tom I sent you a PM about the tachometer parts I mentioned above.
Cluster King
Got it and responded.
#11 | |
Thanks Tom. I will keep mentioning it in threads then, but I will include not to use the HEI's from overseas also. I have no idea what brand tach they sell, or even how many different manufacturers there are. LockDoc
Leon Locksmith, Specializing In Antique Trucks, Automobiles, & Motorcycles (My Dually Pickup Project Thread) http://67-72chevytrucks.com/vboard/s...d.php?t=829820 - Last edited by LockDoc; 05-05-2020 at 11:09 PM. |
Hi Andy-
Do you remember what number LED bulbs you used for your cluster redo? It looks great!
Meet "Old Roy": http://67-72chevytrucks.com/vboard/s...d.php?t=707801 |
#13 | |
Old member
![]() Quote:
Here is the link for the bulbs off Amazon. Note: I used the factory tachs on both my trucks with factory HEI and never had problem. I used one aftermarket tach and it lasted less than 3 months. Brothers made it good though so no complaints but now I run a 3amp in line fuse on the 12 volt wire from fuse block. ![]() https://www.amazon.com/gp/product/B0...?ie=UTF8&psc=1
#14 | |
#15 |
low n' slo
![]() Join Date: Mar 2009
bezel looks great. would u happen to have any night time pics with those leds?
67 1/2 ton Suburban - Project DRGNWGN. Build thread ![]() -_--_--_ _________ _--_-_ -/____|__|__\__ ,.,,,.,.,,.,|_O _______ O_] |
#16 |
Old member
How about a video of it in the dark. This was on the table not in the truck.
They say these are able to dim but they really don't. They do fade just a bit but they are pretty much either on/off. ![]() https://www.youtube.com/watch?v=vRZLojkRjNw
#17 |
Andy...........you did a nice job on that gauge cluster!!!
#18 |
![]() Join Date: Apr 2013
Aftermarket tach works fine with two different HEI’s in my truck. I’m a TBONE customer - can personally say the customer service is top notch. I would recommend.
72 Cheyenne Super C10 SWB 2001 Silverado 1500HD Crew 2011 Silverado 2500HD Crew Duramax (Hers) |
#19 |
Old member
Thanks.
#20 |
low n' slo
yup those look great at night too think i will order me a set of these bulbs
#21 | |
Old member
![]() Quote:
Thanks, I just finished swapping out the mirror in the ramp truck so I snaped a few pictures. ![]()
#22 | |
As soon as I can get to it, I’m putting a new Counterpart Temp gauge in. My Original one started registering hot, and after replacing all the components under the hood and verified that the engine IS NOT running hot, the only component left is the gauge. I was told that they have an integrated resistor so the external one is not needed. |
#23 |
![]() Join Date: Aug 2019
Andy does the stock dimmer work with the LED's? If not what do you use to dim them?
#24 |
low n' slo
from what i have been reading you need to find a dimmable led bulb. not all led bulbs are dimmable.
#25 |
Old member
To answer your question.
I bought them and tried to dim them. They barely would. Basically they don't, they are either on or off. I don't know why any one would want to dim them though. I have owned my truck 35+ years and never dim the dash lights. I have them on full bright all the time so I can see the numbers and not be guessing as to my speed and such. Now that I'm 60 I need them more than ever to be bright. ![]()
