04-29-2020, 03:51 PM | #1 |
1980 C20 Died
So I was on the highway admiring the scenery when all of a sudden I lost all power. Thankfully, I was in a safe spot and pulled over to the shoulder with no issues. Hooked up a jump pack- no start. Got a tow safely home. My alternator is OEM so I figured it gave up the ghost and drained the bat. Purchased a new alt, charged the bat and success. However, today while attempting to start no joy. Cleaned and checked all the grounds. Still have spark. I’m at a loss. When I turn the key interior lights and fan blows. It’s almost like I triggered a kill switch. I know this is vague and I’m barely handy with a wrench, but looking for some solicited advice.
Thanks 44-40 |
04-29-2020, 03:59 PM | #2 |
Re: 1980 C20 Died
So I just turned the key and it started. However, it idles very rough and is acting like it’s fuel starved. Unless I give it gas it dies.
Question- on 1980 fuel toggle switch is LH passenger side tank? Also, just noticed I have fuel coming out near the front of the carb Last edited by 44SAA; 04-29-2020 at 04:09 PM. |
04-29-2020, 06:53 PM | #3 |
Re: 1980 C20 Died
I have seen several Q-jets leak at the front casting plug on the fuel filter housing.
Another thing to check are the hoses from the tanks to the valve and from the valve to the frame as well as from the frame to the fuel pump. Old rotted hoses can let air in. Also an energetic mouse can chew holes in hoses. Could be a plugged fuel filter. Sounds like you have had two closely timed failures. If the battery cables are old, they could be mostly rotted on the inside even if they look good on the outside. Something to keep in mind if you keep having electrical issues. |
04-29-2020, 07:03 PM | #4 |
Re: 1980 C20 Died
Exceptional ideas Parrot, thank you. I replaced the fuel filter. Gonna change the bat cables now thanks to your suggestion. I just cinched down the carb and the leak stopped- guess after 40yrs things jiggle loose. It now starts about half the time very easily.
05-01-2020, 01:42 PM | #5 |
Re: 1980 C20 Died
Okay I am convinced I am starved of fuel. What I’ve done~
1) replaced inlet carb filter and alternator. Also removed fuel line and and caught about 1 pint in 10 seconds- it was really gushing. Maybe pump only works intermittently... 2) confirmed I have good spark and fresh/tested bat 3) truck started and took for a spin 4) after 5 miles truck died 5) started instantly w ether and made it home 6) poured 1/2 cup of gas in bowl and starts instantly and runs for 10 seconds and dies Any thoughts boys? |
05-01-2020, 06:06 PM | #6 |
Robert Olson Transport
Re: 1980 C20 Died
after it gets hot and dies you need to check to see if the fuel pump is pumping
05-02-2020, 01:59 AM | #7 |
Re: 1980 C20 Died
if you suspect a fuel pump failure double check your oil. You can get gas in the oil if the diaphram gets a hole in it.
05-02-2020, 02:29 PM | #8 |
Re: 1980 C20 Died
Yeah so I yanked the carb off- needle was stuck...carb is OEM, time for a rebuild
05-02-2020, 05:44 PM | #9 |
Re: 1980 C20 Died
Stuff just doesn't last anymore, does it?
Current/past Chevy/GMC trucks: 1958 Chevy C-60; 1965 GMC C-50; 1965 Chevy C-10; 1971 Chevy K-10; 1973 Chevy K-20; 1976 GMC C-20; 1977 Chevy C-10 Suburban; 1980 Chevy K-10; 1989 Chevy K1500; 1991 GMC V1500 Suburban; 2016 Chevy K2500 HD Other vehicles: 1988 Jeep XJ; 2011 Toyota 4Runner |
11-06-2020, 01:30 AM | #10 |
Re: 1980 C20 Died
can someone help me out please? anyone own a 1979-1980 c20 suburban (cali
approved not federal) with factory 454 that still has the emission sticker diagram? I really need a picture of it to follow it and put the 454 back to original to pass smog in cali. thank you |
11-06-2020, 01:42 AM | #11 | |
Re: 1980 C20 Died
11-06-2020, 02:09 AM | #12 |
Yes because it’s just a numbers game. This page is not that active and I need to find the right person for such a small specific thing. My chances are slim and only thing to Increase those odds.
Posted via Mobile Device |
11-06-2020, 02:28 PM | #13 |
Re: 1980 C20 Died
Or you are going to annoy everyone that has to read this same question in all these threads, thus decreasing the chances of someone wanting to help you.
11-07-2020, 09:04 AM | #14 |
Just here to tinker
Re: 1980 C20 Died
This is called thread hi-jacking dummy. It is not appropriate for you to clog up everyone's personal threads with your un-related questions just so you can play a "numbers game". Hopefully a moderator steps in and slaps your hand.
78 C10 SWB Diesel #1 (wrecked)http://67-72chevytrucks.com/vboard/s...1978+silverado 78 C10 SWB Diesel #2 (sold)http://67-72chevytrucks.com/vboard/s...d.php?t=650751 60 GMC Suburban (sold)http://67-72chevytrucks.com/vboard/s...d.php?t=445526 60 GMC 1000 (sold)http://67-72chevytrucks.com/vboard/showthread.php?t=298235 67 GMC 1500 (sold) http://67-72chevytrucks.com/vboard/s...d.php?t=803695 73 Chevy C20(Daily)http://67-72chevytrucks.com/vboard/s...d.php?t=852767 86 Suburban(summer unit) http://67-72chevytrucks.com/vboard/s...d.php?t=810697 88 Suburban 4x4(sold) |
11-07-2020, 03:20 PM | #15 |
All about them K’s
Re: 1980 C20 Died
It has been dealt with.
Tyler '57 3100 http://67-72chevytrucks.com/vboard/s...d.php?t=813888 '72 K20 Cheyenne: 5” lift, 35’s, front dana 60 blah blah blah… http://67-72chevytrucks.com/vboard/s...d.php?t=662879 ‘69 K10 SWB: 4” lift 33”s… in a million pieces http://67-72chevytrucks.com/vboard/s...d.php?t=805206 '98 Silverado LT K2500HD ECLB Vortec 454/4l80E: 6" lift 35x12.5x20’s |
