Old 12-10-2003, 09:15 PM   #1
FRENCHBLUE72
PROJECT 7DEUCE
FRENCHBLUE72's Avatar
Angry Need computer help???
Gota gateway here and the waranty has run out need help with pic problem... I am thinking it may be the video card????? Any help would be great...
GO BIG GREEN GO DUCKS
MEMBER #6377
Project "7DEUCE"
Old 12-10-2003, 09:42 PM   #2
72superBB
72superBB's Avatar
Try changing the color quality.
Right click anywhere on your desktop and then go down you properties and click on that.
Click on the setting tab and then down on the right it will say color quality. If it is set at 16 bit, try changing it to something higher, like 32 or 64.
Give that a shot.
Hope this may help.
If your card was going out, it most likely not work at all. This looks like a setting problem.
Life is full of choices and a Chevy is the best choice.
1990 Chevy SWB
72superBB is offline   Reply With Quote
Old 12-10-2003, 09:45 PM   #3
MrShelley
Too Many Clubs Club
MrShelley's Avatar
I agree with 72SuperBB, it's probably a setting problem. A bad card would probably show nothing at all.
Try what he suggested, or do what I always suggest when friends come to me with their Windows problems...I tell them to buy a Mac!
MrShelley is offline   Reply With Quote
Old 12-10-2003, 09:47 PM   #4
Cat Fuzz
My son, my joy.
Cat Fuzz's Avatar
I, respectfully, disagree. Your monitor is toast. You can have it repaired, but a new one won't cost much more.
Cat Fuzz is offline   Reply With Quote
Old 12-10-2003, 09:48 PM   #5
FRENCHBLUE72
PROJECT 7DEUCE
I bought a new monitor already??? So I am pretty sure that 's not it..
MEMBER #6377
Project "7DEUCE"
Old 12-10-2003, 09:52 PM   #6
724x4a/cchevy
Self-proclaimed LED man
724x4a/cchevy's Avatar
More than likely its the video card.
My LED Website
My Photobucket Album of LED's
Ask me about hand-made custom L.E.D brake and reverse lights. <- LINK
I also do LED:
-Third Brake/Cargo
-Brake (truck and burb)
-Reverse (truck and burb)
-67-68 Front Turn Signals
-69-70 Front Turn Signals
-71-72 Front Turn Signals
-GMC Front Turn Signals
I can also do custom lights for other vehicles....i did a set for a AMC Gremlin once
Norwood Survivor
724x4a/cchevy is offline   Reply With Quote
Old 12-10-2003, 09:53 PM   #7
Cat Fuzz
My son, my joy.
Cat Fuzz's Avatar
Your referring to the gray bar in the middle of the screen, right?
Old 12-10-2003, 10:42 PM   #8
71swb4x4
71swb4x4's Avatar
I had problems with my video card, not exactly the same as yours, but anyway it was cheap and easy to put in.
Some people are like slinkies, they aren't good for anything, but you can't help but smile when you see one tumble down the stairs.
71swb4x4 is offline   Reply With Quote
Old 12-10-2003, 10:48 PM   #9
Broken_down?
if you are refering the the bar in the middle of the screen and you have replaced the monitor then it is very likelythe video cards RAM going bad. When the video ram starts to go bad you will start to see little black dots appearing ont he screen. and you can like move a windows oevr the top and it will clear them away. but they keep reappearing. If you have tried and changing resolution then and it still does not work then you should try replacing the video card. But I would liek ( if possible) a better picture of the problem.
Rich
Don't get upset when she marks her territory in the driveway.
WHY DO THEY CALL THEM JUNKYARDS ANYWAY??? I LIKE TO THINK OF IT AS A TREASURE HUNTING MISSION
Broken_down? is offline   Reply With Quote
Old 12-10-2003, 10:50 PM   #10
FRENCHBLUE72
PROJECT 7DEUCE
Broken down I will take a pic and ten post it!!
MEMBER #6377
Project "7DEUCE"
Old 12-10-2003, 10:56 PM   #11
FRENCHBLUE72
PROJECT 7DEUCE
more pic's
MEMBER #6377
Project "7DEUCE"
Old 12-10-2003, 10:57 PM   #12
FRENCHBLUE72
PROJECT 7DEUCE
more
MEMBER #6377
Project "7DEUCE"
Old 12-10-2003, 11:06 PM   #13
72superBB
72superBB's Avatar
Did your try the video quality setting change. I have seen this thing happen and that is usually the problem. Please let us know so everyone can rule things out. This is a simple thing to try before opening up your computer and replacing things.
Ron
1990 Chevy SWB
Old 12-10-2003, 11:09 PM   #14
FRENCHBLUE72
PROJECT 7DEUCE
I am not sure what video quality setting is but I changed the color quality??
MEMBER #6377
Project "7DEUCE"
