04-30-2020, 11:58 AM | #1 |
71 k 20 body mounts issues
Can anyone measure there 71 or 72 k20 body mounts for me? I bought new mounts and now the front is too low and the master cly. is hitting my upper alt. braket. Just need to see if i have the right ones (suppose to be 71-72 4x4) before i start shimming the cab. thanks
jamie72 72 BB cheyenne -- Restoration getting started.. member #807 http://www.myspace.com/whitetailobsession www.antlertalk.com |
04-30-2020, 02:27 PM | #2 |
Proprietor of Dale's Corner
Re: 71 k 20 body mounts issues
Are you sure you don't have a half ton frame? Half ton had shorter rear cab bushings.
"Some Days Chickens And Some Days Feathers" Dale XNGH ECV Sam Brannan 1004 R.I.P. 67ChevyRedneck R.I.P. Grumpy Old Man |
04-30-2020, 06:05 PM | #3 |
no i got the 3/4 the cab is low in front
04-30-2020, 06:32 PM | #4 |
All about them K’s
Can you post pictures of what you’ve got right now? I can measure my mounts in the morning.
Tyler '57 3100 http://67-72chevytrucks.com/vboard/s...d.php?t=813888 '72 K20 Cheyenne http://67-72chevytrucks.com/vboard/s...d.php?t=662879 ‘69 K10 SWB http://67-72chevytrucks.com/vboard/s...d.php?t=805206 '98 Silverado LT K2500HD ECLB Vortec 454/4l80E: 6" lift 315/75/16's ‘87 IROC-Z all original 50K mile survivor TPI 305 IROC Blue ‘10 Camaro 2SS/RS Aqua Blue Metallic #93 -version 2.0 |
04-30-2020, 09:07 PM | #5 |
I got the lmc, full mount kit,its for the 4x4s from what i read they run short, from stock I think i`m about 1/4 low in the from and 1/2 in the back from compairing to a friends pic he sent off his truck.
04-30-2020, 09:10 PM | #6 |
I would greatly appreciate it.
04-30-2020, 09:27 PM | #7 |
The busing kit is different on half ton 4x4 and 3/4 ton 4x4. I have seen this mistake more than once.
04-30-2020, 10:24 PM | #8 | |
That is your problem right there. Look at my truck in my build thread. Pics before I tore it down. Cab is low in back, was that way when I installed the LMC mounts. The new ones I put in are from Classic Heartbeat. Actually ended up a little high in the back. Did not have rear cab bushings seated in frame mount. Should be right on when I re-assemble.
Richard 1972 K10 Custom Deluxe SWB Fleetside My build https://67-72chevytrucks.com/vboard/...d.php?t=800746 |
04-30-2020, 11:53 PM | #9 |
this kit is for a 3/4 ton 4x4
04-30-2020, 11:58 PM | #10 | |
05-01-2020, 12:54 AM | #11 |
All about them K’s
I’m certain longbed K10 and K20 use the Same identical frame model year for model year. With that said bushings shouldn’t make a difference on a long bed 4x4, whether It’s a K10 or a K20. I’ll know know more about the short K10 bushings tomorrow. I’d bet your issue is LMC as well.
05-02-2020, 12:20 PM | #12 |
after adding 2 more shims to the front and 3 to the rear , the mounts are the same height as what i took out,so lesson learned,don`t buy mounts from lmc..
06-11-2020, 11:49 AM | #13 |
The easy way to remember how cab mounts work between the two sizes is C/10s have unique rear cab mounts. They are shorter which means the mount sits higher on the frame. All 20 & 30 series trucks and all k-models take the other mounts. So it can be kept simple with just remembering C/10 is unique, everything else the same
I can't believe they can't even have simple pieces of rubber made to the right measurement. It's not a 1/16" either. Not even close. Are they even trying to get it right?
