Old 04-30-2020, 01:42 PM   #1
Daron65
Question Confused about ported vs. Manifold vacuum.
Can someone please explain which port I should hook up my vacuum advance on my dizzy to? I am running a blueprint 355 that dynoed at 430hp. With hei. I have read good and bad about using both. I know that we have many experienced machanics on this site. Can someone please explain the correct port to me, please?
1971 Chevrolet C20, Blueprint 355. Holly Street Avenger 430HP. Turbo 350
1952 Chevrolet Deluxe. Stock. True survivor with 1 paint job
1953 Buick Special. GM 355. Just a good smooth engine.
Daron65 is offline   Reply With Quote
Old 04-30-2020, 01:50 PM   #2
burnin oil
Re: Confused about ported vs. Manifold vacuum.
This is one of those try it and see how the motor likes it. Generally manifold vacuum is best. It will give you vacuum advance at idle. You usually do t have an issue with to much advance since it will drop off as the throttle is applied.
burnin oil is offline   Reply With Quote
Old 04-30-2020, 03:59 PM   #3
Steeveedee
Who Changed This?
Steeveedee's Avatar
Ported spark was used to reduce emissions back in the day. More advanced timing produces more oxides of nitrogen. Your engine will idle better and potentially idle cooler with manifold vacuum instead of ported vacuum, and will have slightly better off-idle response.
~Steven
Simi Valley, CA
Steeveedee is offline   Reply With Quote
Old 04-30-2020, 04:14 PM   #4
heskahoka
heskahoka's Avatar
I have the same setup in my pickup, a Blueprint 355 with HEI.
My mechanic and I started with ported then ended up on manifold vacuum.
It runs very smooth across the power band on manifold vacuum. As I recall, it was easier to set a lower idle after we switched to manifold.
As others have said, the ported was for early emissions setups.
heskahoka is offline   Reply With Quote
Old 04-30-2020, 04:36 PM   #5
Corts60
Just here to tinker
Corts60's Avatar
x2
Old 04-30-2020, 05:24 PM   #6
toolboxchev
Try this for reference material:https://www.crankshaftcoalition.com/...EI_distributor
I use the adjustable vac advance. Gives more room for tuning.
toolboxchev is offline   Reply With Quote
Old 04-30-2020, 07:37 PM   #7
Daron65
Thank you all for the information.
