04-30-2020, 09:56 PM | #1 |
control arms
is there any difference in the length of the upper or lower control arms measured from cross shaft to ball joint 67 -70 or 71-72 I know the ball joints are different my question is will all A arms upper or lower fit 67-72 can you mix any years upper and lower if you correct the ball joint issue thanks in advance
Grand Theft Auto https://67-72chevytrucks.com/vboard/...d.php?t=855961 Doc & Kim build http://67-72chevytrucks.com/vboard/s...d.php?t=722288 I am from the desert http://67-72chevytrucks.com/vboard/s...d.php?t=650332 basket case build SOLD http://67-72chevytrucks.com/vboard/s...d.php?t=648557 |
05-01-2020, 09:16 AM | #2 | |
Re: control arms
05-01-2020, 10:46 PM | #3 |
Re: control arms
Thank you
