Old 05-02-2020, 01:54 AM   #1
val1gonzales
auto trans. shift indicator light
Anyone know where I can find one of these for a 66 C1o automatic column? Even if its the entire turn signal harness.
val1gonzales is offline   Reply With Quote
Old 05-02-2020, 08:18 AM   #2
The Rocknrod
Moderator
The Rocknrod's Avatar
Re: auto trans. shift indicator light
This cannot be a wanted to buy thread or it will be shut-down!
You could "Call" one of the used parts dealers:
http://www.billstruckshop.com/60-66used.html
https://www.aspenautoaz.com/60-66-ch...uck-parts.html
http://www.4-5-6chevytrucks.com/used-parts.html
http://ctcautoranch.com/index.html
https://dennischevytruckparts.com/ch...s-years-60-66/
Old 05-02-2020, 01:25 PM   #3
val1gonzales
Thanks for the links RnR. After some research I come to find out that they are also in 63 -64 Chevy Impalas with an automatic shift column. Research consisting of me going to the junk yard and looking at 60's cars and trucks. Most 64-66 trucks were standard and not automatic transmissions. Therefore, this piece is often not included in the turn signal assembly. The usually empty last slot position on the connector is just for this light.
