Old 05-02-2020, 03:26 PM   #1
Pontiac1976
Pontiac1976's Avatar
The Back Glass
Hello all. The 73-87 pickup half Back Glass.
Can any one get or tell me the top length of the rubber for the glass (outside)
Thanks.
1977 REG cab Long Bed with a 1984 Front Clip, 82 305 .60 over 9.0.1 flat top pistons, 4bbl, TH350, w/84 SS-intake & cam , w/ 1977 big block rad, 1975 gear box, 1984 master w/ metric fittings top & SAE fitting @ portion block, 1975 3.42 gear open diff. Duel 77-87 Factory air cleaner, duel inlet from rad support . Down sized 9' to new 8' Steel flat bed
Was a 77 454 w/308 gear. Taken out 550 lbs. up front with motor clip change.
Pontiac1976 is offline   Reply With Quote
