Old 12-10-2003, 10:14 PM   #1
daddybullfrog
Active Member
daddybullfrog's Avatar
Cargo Light Bulb?
The cargo light bulb burned out in my '72. When I changed it out, the thing twisted off and I damaged the old bulb. No big deal except taht i cannot identify the bulb. What's strange is the bulb has two contacts on the base and a single element. The socket also has two contacts. Does anyone know why this is? This is a factory cargo light.
'67 C-10 short stepside
'72 K-10 Cheyenne Super under construction
daddybullfrog is offline   Reply With Quote
Old 12-10-2003, 10:19 PM   #2
rage'nrat638
rage'nrat638's Avatar
yup thats the stock gOOfy bulb.....
i got one with the new cargo light i ordered....looked at the parts store they did not have it
i changed it right away before i install it....got one laying here...
i guess i could go look for the number
rage'nrat638 is offline   Reply With Quote
Old 12-10-2003, 10:25 PM   #3
rage'nrat638
12V32CP DON'T ASK ME
Old 12-10-2003, 10:25 PM   #4
daddybullfrog
Active Member
I'd appreciate it greatly! Why does it have two contacts and one filament?
Old 12-10-2003, 10:25 PM   #5
john
member #16
john's Avatar
The reason for two contacts is they use the orange and white wires from the dome light circuit,and the orange one is hot all the time and the white completes the ground. Other wise you would feed back into your dome light.
john is offline   Reply With Quote
Old 12-10-2003, 10:29 PM   #6
daddybullfrog
Active Member
That makes sense. Thanks for the info. Merry Christmas from New Mexico!
Old 12-10-2003, 10:45 PM   #7
jhow66
jhow66's Avatar
#1142
56 Chevy Bel-Air 2dr. HT (purchased new)
71 Chevy Cheyenne SWB PU (502HO)
65 GMC short bed step--work in progress and my gofer
jhow66 is offline   Reply With Quote
Old 12-11-2003, 12:23 AM   #8
cdowns
cdowns's Avatar
all light bulbs have 2contacts
Old 12-11-2003, 03:55 PM   #9
desertchevy
I put a 1004 in mine.Two contacts one element
2006 Dodge Quad Cab 4X4
2001 Chevy Impala
2006 Corvette
2009 Fusion
1964 Toyota Landcruiser FJ45 Wagon
desertchevy is offline   Reply With Quote
Old 12-11-2003, 04:11 PM   #10
Gene
Gene's Avatar
Not necessarily true, the light bulbs that illuminate the a/c heater controls have only 1 positive contact.
1971 SWB 4X4 Build
BOARD MEMBER #5448
BOOMER SOONER!!!!
Gene is offline   Reply With Quote
Old 12-11-2003, 04:39 PM   #11
cdowns
cdowns's Avatar
HAH a lightbulb with 1contact !! how is the electrical circuit completed??? there MUST!!!! be a positve and a negative contact for illumination !!!!!!!!!!!! there's no such thing as a light bulb with 1contact go back to basic electricity class !!!!!!!!!!!
Old 12-11-2003, 05:37 PM   #12
Dean
Dean's Avatar
Isn't the outer case the other contact/ground? I think he meant there is only one hot contact.
Anyone make a brighter light for a cargo light? Like a halogen or something??
Dean is offline   Reply With Quote
Old 12-11-2003, 06:36 PM   #13
tom hand
CCRider
tom hand's Avatar
The reason it has two contacts on the base and one filiment, is it does not use the brass base for a ground as most bulbs do
72 GMC Sierra SWB almost finished---- 84 Softail
Olive Branch MS
tom hand is offline   Reply With Quote
Old 12-11-2003, 09:03 PM   #14
Gene
Gene's Avatar
Last basic electricity class was in high school but I retained some knowledge. So using your logic all lightbulbs have 3 contacts? Geez, don't get your panties in a wad. I guess I should have clarified myself, not all lightbulbs have 2 contacts on the bottom of the bulb
1971 SWB 4X4 Build
BOARD MEMBER #5448
BOOMER SOONER!!!!
Old 12-11-2003, 09:03 PM   #15
jhow66
jhow66's Avatar
Check your backup bulb in your truck--1156--1 contact--grounds thru brass. ( last class was in 1954 at UT-go Vols)
Old 12-11-2003, 09:07 PM   #16
cdowns
cdowns's Avatar
duh a ground is a contact
Old 12-11-2003, 09:11 PM   #17
jhow66
jhow66's Avatar
Right but only one contact on bottom unlike a 1142 which has two on bottom which does not ground thru case. (electricity 101)
Old 12-11-2003, 09:13 PM   #18
Gene
Gene's Avatar
Duh? My 9 year old argues like that Some flourescent lightbulbs have 4 contacts.
1971 SWB 4X4 Build
BOARD MEMBER #5448
BOOMER SOONER!!!!
Old 12-11-2003, 09:40 PM   #19
cdowns
cdowns's Avatar
yes true some light bulbs have more than 2contacts like the mentioned dual filament 1142 that has 2contacts for the filaments and a3rd contact where it grounds thru the case
what's getting confused by those unfamilar with electricity is that i stated A LIGHT BULB MUST HAVE 2CONTACTS and yes it can have more like the 1142 with three or the flouresents or headlights but a light dont work with 1contact NEVER
Old 12-11-2003, 09:51 PM   #20
jhow66
jhow66's Avatar
1142 has one filament and 2 contacts on bottom. Does not ground thru case. It works like John says. We all know that you have to have a complete circuit to ground. I have wired many street rods and machines from scratch including fuse panel. Was not trying to put you down-just having a little fun.
Old 12-11-2003, 10:03 PM   #21
Gene
Gene's Avatar
Yeah, Not trying to make you look bad cdowns, I just pointed out something that I saw that seemed incorrect. We're basically saying the same thing but wording it different. BTW I am very familiar with basic electrical properties. I wired my shop and my 71 Chevy and have done many electrical repairs to my home. Even have to wire in proximity switches, photo eyes and numatic solenoids from time to time in my line of work.
1971 SWB 4X4 Build
BOARD MEMBER #5448
BOOMER SOONER!!!!
