BlahBlahBlah
Flatbed question
68bowtie's build inspired me to get back my C30. The new owner wasn't doing anything with it so we made a deal. It wont be home for at least three weeks now so Im doing a little planning.
I really love the way 68bowties built his bed. I was hung up on making mine a dump bed and the cost led me to be kind of negative on this truck. Ive been looking at a ton of flatbeds now and while I really like his D-ring set up on the sides of his bed, I really think I would like stake pockets. I saw this ride on craigs list. Good looking bed with stake pockets. Can you tell me what the use of the strapping that goes around the edge of the pockets and beds is for? Link to 68bowties truck thread. And the pic of the flatbed in question. http://67-72chevytrucks.com/vboard/s...21#post8725321
At the body shop.
Re: Flatbed question
On a big truck flat bed its refereed to as the rub rail
" That didnt make it any newer " " Dont antique the equipment " |
20' Daredevil (Ret)
![]() Join Date: May 2003
That would make sense, something to keep the pockets from sticking out where they could get bent or torn off.
#4 | |
At the body shop.
You could add a round tube between each stake pocket for additional tie down loop on the outside of your bed. And something like these for the bed floor. https://www.ebay.com/itm/183747938160
" That didnt make it any newer " " Dont antique the equipment " Last edited by KQQL IT; 05-03-2020 at 04:15 PM. Reason: Pic |
Post Whore
![]() Join Date: Feb 2016
That flat bar strap is what flat bed semi trucks hook their tie down straps to. Super handy and tough, but now you be looking for them all the time along the highways, then stopping to pick them up.
Thanks to Bob and Jeanie and everyone else at Superior Performance for all their great help. ![]() RIP Bob Parks. 1967 Burban (the WMB),1988 S10 Blazer (the Stink10 II),1969 GTO (the Goat), 1970 Javelin, 1952 F2 Ford OHC six 4X4, 29 Model A, 72 Firebird (the DBP Bird). 85 Alfa Romeo If it breaks I didn't want it in the first place The WMB repair thread http://67-72chevytrucks.com/vboard/s...d.php?t=698377 |
The small, rectangular slots act as pockets for stakes for sides, too. I have a similar set up on my cannon trailer.
'69 Longstep K-10: 327/SM465/T-221/Closed Knuckle Dana44/12-bolt. |
#7 | |
BlahBlahBlah
Post Whore
The metal hook on the end slides down between the bed and the flat bar from the top with the open end of the hook away from the bed. Then it hooks under the flat bar. Do the ratchet side first and let it hang over the flat bar. Then go to the other side and hook the loose strap's hook the same way and toss the end over the load. Then feed the loose end into the ratchet's slot and pull up, pulling the ratchet up while keeping the hook under the flat bar. Then tighten the ratchet up until the strap is tight. Remember to put one twist in each side to prevent the straps from fluttering in the wind slowly becoming fuzz until the strap breaks. Next time you see a flat bed semi load take a look and you will see what I mean.
![]() Join Date: Nov 2018
Here's how they work the top of the tube sits flush with the bed and you pull it up to hook your chain to.
https://www.easternmarine.com/traile...-lbs-1901006-0 |
At the body shop.
Mount the top flush with your bed. When you need an anchor you pickup the end cap and you have a chain tie without wrapping around the rub rail or bed side.
BlahBlahBlah
Ok now I get it thanks!
I like these. When you need them they are there. Otherwise a clean flatbed.
https://www.buyersproducts.com/produ...ket-d-ring-680
1955 GMC 250 8 Flatbed 1971 C30 157" 350 4spd 10' Flatbed 81 GMC K30 CnC 9' Flatbed 454 T400 89 GMC Jimmy Stock https://67-72chevytrucks.com/vboard/...d.php?t=810958 71 LT1 Convertible, 72 Coupe 69 CJ5, 75 CJ6, 67 M715, 72 M35A2 Bobbed, 95 XLC2 |
