05-03-2020, 07:00 PM | #1 |
Location: 3,018 feet above the SoCal/Mojave Desert region.
Rear shock mount stripped. Now what??
Still restoring the frame. The nut just kept turning. I finally removed the rear shocks and this is the results. I had to cut the shock to make room to cut the bolt. Now what?? Both sides. Thanks.
05-03-2020, 08:46 PM | #2 |
Re: Rear shock mount stripped. Now what??
They make a bolt in mount, cut that one off, drill it and install one of these.
https://www.summitracing.com/parts/c...+5ba150fd58b68 |
05-03-2020, 08:56 PM | #3 |
Post Whore
The bolt should the same as the upper bolt on the front shock. Some simple measurements will confirm this. You can buy those bolts at NAPA. You can cut the bad bolt off and then drill the base of it out so you can bolt a new one in its place.
Thanks to Bob and Jeanie and everyone else at Superior Performance for all their great help. RIP Bob Parks. 1967 Burban (the WMB),1988 S10 Blazer (the Stink10 II),1969 GTO (the Goat), 1970 Javelin, 1952 F2 Ford OHC six 4X4, 29 Model A, 72 Firebird (the DBP Bird). 85 Alfa Romeo If it breaks I didn't want it in the first place The WMB repair thread http://67-72chevytrucks.com/vboard/s...d.php?t=698377 |
05-03-2020, 09:57 PM | #4 | |
Look here:: https://www.foothilloffroad.com/susp...t-3-p1584.html OR modify this one if you have a lathe to take down to 1/2 https://www.foothilloffroad.com/susp...k-mount-2.html Last edited by kwmech; 05-03-2020 at 10:23 PM. |
05-03-2020, 11:00 PM | #5 |
Who Changed This?
That pig is welded on? What year truck is that? Mine are all bolted on.
05-03-2020, 11:07 PM | #6 |
Forgot to mention this is a '69 GMC 3/4 ton. If it makes a difference or not. I like the bolt-in type as I can drill a hole. I cant weld and dont know anybody that does. But it wont hurt to drive it to a shop without shocks to have them welded in.
05-03-2020, 11:08 PM | #7 | |
05-03-2020, 11:16 PM | #8 |
My KYB front shocks came with the extra bolt. I am planning to use them on the rear, they are identical.
Bolt in style, no big deal. |
05-04-2020, 01:19 AM | #9 |
Yeah, the smooth part where the shock sits is 5/8''. So you would need a different shock without the steel sleeve or get the correct pin. Years ago I had the same problem with broken pins on my flatbed and I removed the pin pictured and drilled the hole out to 5/8'' all the way through the frame rail and installed a long 5/8'' grade 8 bolt and replaced the shock. I was changing the rear axle anyways from the HO72 to a D70hd
05-04-2020, 04:59 PM | #10 |
See if a muffler shop might be able to help u out
Mike 72 C-10 Cheyenne off frame resto and Upgraded to 4 wheel disk, Tilt, Dakota Digital Dash / Rear slider. 421 SBC / TH350 3000RPM Stall Progression Ignition /Holley 750 DP/3:73 gear Eaton Limited Slip unit / 2 1/2 exhaust glasspacks |
