Old 05-04-2020, 08:40 AM   #1
Afirehawk1
66 C10 Headlamp Ground Wiring
is this the correct location? i think it mounts to the rear of this hole?
Afirehawk1 is offline   Reply With Quote
Old 05-04-2020, 09:28 AM   #2
The Rocknrod
Moderator
The Rocknrod's Avatar
Re: 66 C10 Headlamp Ground Wiring
I'd do a continuity check to ground if you do that.
Old 05-04-2020, 10:01 AM   #3
Afirehawk1
Originally Posted by the rocknrod View Post
i'd do a continuity check to ground if you do that.
10-4
Old 05-04-2020, 10:28 AM   #4
vince1
IMO GM really cheaped out on their headlight wiring. How thick is that original ground wire, #18? I can't remember exactly which hole it goes to.
vince1 is offline   Reply With Quote
Old 05-04-2020, 10:44 AM   #5
Afirehawk1
i upgraded to the American Autowire Classic. appears bigger than 18 gauge
i think my photo is correct
just need some concurrence
Old 05-04-2020, 11:17 AM   #6
vince1
I can check tonight if you haven't got an answer by then.
Old 05-04-2020, 11:35 AM   #7
Afirehawk1
very much appreciated.
Old 05-04-2020, 06:05 PM   #8
vince1
Where you have that eye with the wire attached I see a sheet metal screw coming out in the forward direction. That would mean the wire gets attached on the back side. I saw this by taking the ring off. I did not see a wire behind it, just assume it is there. I think I'd have to take the grill off to see it properly.
Edit: And seeing I have been messing with them there is no guarantee that they are as original.
Old 05-04-2020, 06:14 PM   #9
DPowers
DPowers's Avatar
Back side of the bracket.
DPowers is offline   Reply With Quote
Old 05-04-2020, 06:19 PM   #10
DPowers
DPowers's Avatar
another one
Old 05-04-2020, 07:37 PM   #11
Afirehawk1
Originally Posted by DPowers View Post
another one
Bingo.
Thanks DP. I guessed correctly
Old 05-04-2020, 10:02 PM   #12
VictoriaHardware
VictoriaHardware's Avatar
It looks like you have recently painted the headlamp bracket. Do yourself a favor and put a star washer between the ring terminal and the headlamp bracket. The washer will dig through the paint and ensure continuity, not just counting on the screw to cut the paint with it's threads.
The threads of the 3 bolts that hold the bracket to the grille panel are the next path electricity takes to get back to the negative battery cable.
VictoriaHardware is offline   Reply With Quote
