Old 05-04-2020, 11:47 AM   #1
Ehodg66
Ehodg66's Avatar
Door lock actuator bracket
My passenger side door was missing the door lock actuator bracket. I ordered the actuator from LMC thinking the bracket may come with it, because it doesn't show as a separate part on their site. It did not come with. I've reached out to LMC, but yet to hear back.
I cannot seem to find just the bracket online.
Anyone have an extra they want to sell or know where I can pick one up?
I've attached a pic of my drivers side bracket.(still having issues with pic orientation?)
thank you
Ehodg66 is offline   Reply With Quote
Old 05-04-2020, 12:15 PM   #2
Pontiac1976
Pontiac1976's Avatar
Re: Door lock actuator bracket
Any one that has a 73-91door that had power locks that left the bracket on the door or scrap yard GM 73-91Burb,jimmyC/K trucks.
1977 REG cab Long Bed with a 1984 Front Clip, 82 305 .60 over 9.0.1 flat top pistons, 4bbl, TH350, w/84 SS-intake & cam , w/ 1977 big block rad, 1975 gear box, 1984 master w/ metric fittings top & SAE fitting @ portion block, 1975 3.42 gear open diff. Duel 77-87 Factory air cleaner, duel inlet from rad support . Down sized 9' to new 8' Steel flat bed
Was a 77 454 w/308 gear. Taken out 550 lbs. up front with motor clip change.
Pontiac1976 is offline   Reply With Quote
