05-04-2020, 03:24 PM | #1 |
steering wheel swap
Hi guys,long time lurker here and first time posting.
I have a 78 chevy c10 and want to swap the steering to one out of a 99 suburban but i'm not sure if it will fit. Anyone knowif it will fit on the 78? I'm talking about the air bag wheel. Last edited by TXGREMLIN; 05-04-2020 at 03:38 PM. |
05-04-2020, 04:09 PM | #2 |
Re: steering wheel swap
No. not unless you make a adapter
1977 REG cab Long Bed with a 1984 Front Clip, 82 305 .60 over 9.0.1 flat top pistons, 4bbl, TH350, w/84 SS-intake & cam , w/ 1977 big block rad, 1975 gear box, 1984 master w/ metric fittings top & SAE fitting @ portion block, 1975 3.42 gear open diff. Duel 77-87 Factory air cleaner, duel inlet from rad support . Down sized 9' to new 8' Steel flat bed Was a 77 454 w/308 gear. Taken out 550 lbs. up front with motor clip change. |
05-04-2020, 05:10 PM | #3 |
What Pontiac said. Airbag style columns/wheels use a different spline than earlier ones. If it was a 94 or early wheel it would work.
05-04-2020, 05:24 PM | #4 |
Thanks guys,guess i'll see if they have one of the earlier ones out there.
05-04-2020, 07:46 PM | #5 |
This is the one I put in my truck. From the 88-94 era.
05-04-2020, 11:43 PM | #6 |
05-05-2020, 06:05 AM | #7 |
IIRC - most pre air bag GM steering wheels use the same spline/bolt/horn setup. So a Pontiac wheel will mount on a Chevy column. It may not match style wise however. Just be sure to get ALL the horn parts.
When I picked up a replacement steering wheel for my 75, I test fit 3 on a wheel-less column before picking one from a Blazer. I liked a Pontiac wheel but it had a square base that didn't match very well to the round Chevy column. |
