05-04-2020, 08:03 PM | #1 |
GMC vs C10 Chassis
I have a 68 GMC Long Bed Chassis, can I use is to build my 1968 Chevy Long Bed? Changes I have to make?
Thx, Mike
Make it a great day! Mike |
05-04-2020, 08:21 PM | #2 |
Re: GMC vs C10 Chassis
Depends on what motor/trans/rear are in the two trucks. The suspension stuff should be the same except possibly the leaf/coil thing.
Either truck could be had with either rear suspension, just depends on what was ordered. Motor mounts/brackets/trans crossmembers will need to be switched once again depending on what combo it came with.
05-04-2020, 08:26 PM | #3 |
[QUOTE=Mike C;8732274]Depends on what motor/trans/rear are in the two trucks. The suspension stuff should be the same except possibly the leaf/coil thing.
Either truck could be had with either rear suspension, just depends on what was ordered. Motor mounts/brackets/trans crossmembers will need to be switched once again depending on what combo it came with.[/QUOTE The gmc had the v6 and 4 spd. Going to 350 and 350 tranny. Posted via Mobile Device |
05-04-2020, 10:05 PM | #4 |
No difference Chevy to GMC
05-04-2020, 11:34 PM | #5 | ||
"I ain't nobody, dork."
I have a 1972 GMC C1500 long bed that was originally a leaf sprung rig. That now has a 1969 C10 long bed trailing arm frame under it. I swapped all the 1972 5 lug front end and disc brake stuff up front. I also used Moser 5 lug conversion axles in the 1969 12 bolt diff.
Gary
'cuz chicks dig scars... My 1972 GMC 1500 Super Custom (Creeping Death) "long term" build thread. The Rebuild of Creeping Death after the wreck Quote:
05-05-2020, 12:04 AM | #6 |
Thanks for all the input!!
Cheers and be safe!!!
