05-05-2020, 01:25 PM | #1 |
1978 Steering Shaft
I’m looking into redoing my steering, new gear box and new shaft. I read about swapping in a Jeep Cherokee u-joint shaft works great. The truck this would be going in is a 78. I’m getting conflicting info researching this, some say it works on all trucks 73-87. And some say it only works on 79-87. Does anyone know which one is correct?
1978 GMC K25 1984 Chevy Scottsdale K10 built 350 4"lift - SOLD |
05-06-2020, 10:38 AM | #2 |
Re: 1978 Steering Shaft
I need to know the exact same thing so I will be watching. Thank you for asking about this.
05-06-2020, 02:05 PM | #3 |
I believe up to 79 had a splined shaft end on the steering column and 79 and after is a double d.
05-06-2020, 11:40 PM | #4 |
Dang so it won’t work. Ok thank you
05-07-2020, 09:17 AM | #5 |
It is really easy to check your column. if the bolt goes through the center of the intermediate shaft it is double D. If it clamps at the side, it is splined
AZPartsLocators on Instagram 1972 Cheyenne Super Short Bed big block "Blackie" 1977 Crew Cab GMC Short bed with 4BT Intercooled Cummins Diesel and a 4L80e "The Junkyard Dog" 1985 Crew Cab Chevy dually with 5.9 Cummins "The Big Dog" This is what my dad liked to be called by the grandkids before he passed so it seems fitting for his old truck. |
