Is there a body panel bolt list for a 66 C10 Fleetside?
I'm looking to get a list to place an order of stainless steel bolts and I wondered if there is a list of the needed bolts when doing a restoration? Ive taken out the bagged bolts I had and from here would need to go to the hardware store and get the sizes and thread pitches to place an order.
I have been buying over the years a few packs here and there and have a few already... Engine compartment bolt kit -- (Battery Box, Radiator, and core support accessories --35 bolts, washers and lock washers) Radiator Core support kit (dont think its stainless-made by counterpart) Bed Bolt Kit https://www.classicparts.com/1960-66...ctinfo/08-117/ Bumper bolts front and rear - Chrome not stainless Ill list the bags and bottles of bolts I listed when I dismantled. Im not sure if they are all there, some hardware just broke apart in the dismantling. I will also list what I think I need and if Im off please let me know. 5/16-18 x 3/4", (pointed tip with solid/fixed washer head on bolt top) = 33 of these https://www.allensfasteners.com/deta...duct_ID=A10084 5/16-18 x 3/4", (pointed tip with a loose washer head on bolt top) = 35 of these Ive seen the same size but instead of a fixed lock washer head they have a loose washer underneath. Not sure why they used the two different types? 30 bolts that are the same ones used for the bed side panels and the wheel tubs, not sure what size these are. Shims = 16 or so (unless I just re use what I have and paint them so they dont rust?) I havent seen stainless ones yet, Im sure they are there though. https://www.allensfasteners.com/deta...duct_ID=A+3000 |
| Bookmarks |
