Roto Reuter thats the name...
![]() Join Date: Feb 2010
Transfer case shifter arm boot orientation
I've seen this transfer case shifter boot installed two different ways and I'm trying to determine which way is correct.
I believe it is supposed to go with the thicker part at the top of the boot facing rearward. I can't find any pictures to show that this is the right way. Pictures would be helpful too. Thanks. This picture in the LMC catalogue shows it the other way.
~ Dan ![]() My 70 K10 SWB build:http://67-72chevytrucks.com/vboard/s...d.php?t=782232 My 71 SWB build:http://67-72chevytrucks.com/vboard/s...d.php?t=651394 1970 SWB Fleet K10 4X4, 5.3L LM7, 4L60E, Dakota Digital RTX, Vintage Air, Ididit tilt 1971 SWB Fleet C10 - Original SWB Arizona truck, new custom restoration project "Kick out your motor and drive while you're still alive - kick it out!" - Heart 1977 |
#2 | |
![]() ![]() Join Date: Oct 2015
Re: Transfer case shifter arm boot orientation
1972 Blazer Highlander 1971 GMC K1500 SWB (sold) 2004 Corvette Z06 CE |
Anyone else?
yer going to be hard pressed to find someone that can swear to that level of detail on something where the functional difference is so insignificant and even the aesthetic difference is so slight.. also finding enough vehicles that are known to either have never had the boot removed or had the boot removed but know it to be the correct orientation..
dealer pictures, brochures, parts and service manuals may provide enough to draw a conclusion.. you might try Joesjunk, Keith Seymore, Chevyland?? or any of these guys with a dozen truck listed under their names ![]() for what it's worth both of my suburbans are opposite of each other, or at least the white one looks like it's facing the other way.. but it's kinda mushy looking like it may not even be oe or an oe part so who knows.. and I certainly don't know enough history on these to swear either of them are factory oriented.. if I was to hazard a guess, since the lever leans forward in 2H, I would think the top of the boot would lean the same way so the lever is perpendicular to the hole, like my blue one.. good luck! ![]() ![]()
I started out with nothing - and I still have most of it |
I'll check with joesjunk. I know he has some 4X4's. In the meantime if anyone knows, chime in. I've had no luck when checking service manual and assembly manual.
![]() Join Date: Apr 2000
i have an oem one that i was cleaning last night to reuse and it has front writen on it,the one with the blue ring in previous post is correct.
jamie72 72 BB cheyenne -- Restoration getting started.. member #807 http://www.myspace.com/whitetailobsession www.antlertalk.com |
Thanks for your input Jamie. This is the way I believe it should be.
![]() Join Date: Dec 1999
The one in my 72 was mounted the same as the blue ring in Killer Bee's post and tim71's. Can look to see if original and has markings on Monday.
Richard 1972 K10 Custom Deluxe SWB Fleetside My build https://67-72chevytrucks.com/vboard/...d.php?t=800746 |
![]() Join Date: May 2001
The boot picture with the blue ring is correct
72 3/4t Custom Deluxe 402/auto 66k Original paint 71 3/4t 4x4 Custom Deluxe 10k original miles Original paint 71 3/4t Cheyenne 402 70k original paint 72 3/4t 4x4 Custom deluxe 72 3/4t 4x4 Custom deluxe 91k original paint 72 Cheyenne/30 Dually 69 Camaro SS396 4-speed 13 GMC 2500HD Duramax I bought new 05 Jeep Wrangler "Willys Edition" 12k miles (I bought new) 85 3/4 ton 4x4 Scottsdale 33k miles original paint 86 1 ton 4x4 SRW Silverado 454 restored 80 1 ton 4x4 SRW Silverado 9,434 original miles!! original paint 95 GMC 1 ton dually 4x4 my dad bought new 95 GMC 3/4 ton 4x4, regular cab 454, 31k original miles 2002 2500HD 4x4 regular cab 6.0L 67k miles 2002 2500HD 4x4 regular cab 8.1L 28k miles 2003 GMC 2500HD 4x4 regular cab Diesel 93k miles 67-72 Parts for sale |
Thank you for confirming.
