05-07-2020, 04:49 PM | #1 |
71 fuel pump install issue
replacing mechanical fuel pump, did not anchor with longer bolt as was suggested in this forum. Saw the thread after the fact. I cannot seem to get the rod into the up position or to move at all. This is my first fuel pump install so i do not have a reference point of how much that rod should move, how to move it, and how easily it should move. How do I get this into the up position?
I have tried cranking it several times, appears not to be moving. Any suggestions? TIA |
05-07-2020, 04:59 PM | #2 |
Re: 71 fuel pump install issue
Remove the plate that the fuel pump bolts against and you will have access to the fuel pump push rod. You will be able to identify if its stuck or anything. It should slide out you can clean it up and inspect and reinstall. With the motor bumped over to allow it to seat farther in then you should be able to install a bolt as mention to get the pump installed. I normally use a little bit of tacky grease on the push rod that allow it to hold in place long enough to install the pump.
65 C-10 Times gone by(Sons truck)http://67-72chevytrucks.com/vboard/s...92#post6164692 70 C-30 Tow truck AKA Highlighter 02 Silverado 2500 HD CUCVII Tow Rig/DD 1968 C10 Project Quarantine http://67-72chevytrucks.com/vboard/s...d.php?t=804800 1980 Buick Regal Dirt Stock car |
05-07-2020, 05:15 PM | #3 |
Don’t feel bad it’s a ***** the first time you install a new fuel pump. The grease is a good trick to help keep the push rod out of the way while tightening the retaining bolts..
71 C-20 07 Magnum RT AWD |
05-07-2020, 05:34 PM | #4 |
I've used an old hacksaw blade (bent it)to get under the end of the push rod, and push it up. THen slip the arm of the pump in...
05-07-2020, 06:06 PM | #5 |
I’ve used a 4 inch common nail with the end bent to 90 degrees.
Hooked it on the bottom side of the rod and pushed it up. Slipped a hacksaw blade in to keep it from sticking down. And I’ve used an awl like this. https://www.whitecap.com/MarMac-Manu...LMDKEA-104MWTT |
05-07-2020, 06:14 PM | #6 |
Your block also may have a bolt on the front of the block that lines up with the fuel pump rod. if so remove the bolt and install a longer bolt, push up on the fuel pump rod and them hand tighten the bolt. This will keep the bolt from dropping down while installing the fuel pump. When your done don't forget to remove the longer bolt and reinstall the short bolt, otherwise you will have an oil leak.
Also note, not all blocks have this hole drilled out. My GM crate engine didn't.
Terry 1970 Custom Camper/C20 , GM Crate 350/7004R, Dana 60, factory AC |
05-07-2020, 06:30 PM | #7 |
Good advice above - may need to bump engine to get cam off the rod. Have used very skinny light angles pliers to hold the rod up long enough to get new pump arm under it and also have used shim material bent at about 90 degrees to slip under end of rod and hold it up - the sticky grease suggesteion above works well , too. Just be patient. If you have the hole in the front of the block, it;s the eaasy way. I don't even use a longer bolt - just ask my wife to hold a long punch in there to lock the rod in place.
CCCC 67 Sting Ray Coupe 327 4sp; 68 K10 Suburban 327 4sp; 69 K20 Lifted 383 4sp; 69 C80 Fire Truck 478 V6 5sp/2sp; 69 C20 Longhorn 327 4sp; 70 C30 Wrecker 350 4sp; 70 C30 Flat Bed 350 4sp; 71 C20 LWB 350 4sp; 72 K5 Blazer 350 4sp; 72 C30 Flat Bed Gooseneck Hauler with sleeper 350/TH400; 72 C20 Longhorn 402 4sp; 52 Mack LTL Supercharged Cummins 5sp x 3sp; 01 Dodge 5.9 HO Cummins 6spd; 02 Safari Trek 2430 8.1 Vortec on Workhorse Chassis; 03 Silverado 2500 HD 4wd Duramax/Allison Moved but still in the family 70 C20 Custom Camper 350/TH350; 72 K5 Blazer CST Highlander 350/TH350 Recently sent to new homes 72 C30 MoHome 402 4sp; 72 K5 Blazer Conv 350 4sp; 75 GMC 6000 Aerial 350 w Allison; 72 GMC 3500 Utility 350 4sp; 70 GMC 3500, 350 4sp |
05-07-2020, 06:43 PM | #8 |
also forgot to mention when the rod is on the low side of the cam it will be maybe 1" from the top of the hole. I've been told that at TDC the rod is all the way up.
05-07-2020, 06:52 PM | #9 | |
This was my first time installing one, and after an hour of failing had to search the internet for a solution. It was funny once I got it installed.
Steve/NH 1967 K10 327 Short Bed Stepside 2008 F350 Power Stroke Lariat 2007 BMW X3 2023 BMW X3 M-Sport 2020 BMW 540xi M-Sport 1995 Harley FLSTC |
