05-07-2020, 05:56 PM | #1 |
What's the deal with original bumper nuts?
These are original nuts installed with the front bumper and brackets. I imagine the same nuts were used for a rear bumper as well. Anyone know what type of nut they're called? I wonder if they're reproduced, I can use another eight or so.
What's the deal with the slots? Only advantage I see is penetrating oil, maybe that's exactly what the nuts are designed for. I don't see a locking advantage, perhaps I'm missing it. Thank you
Tony 71 Custom Deluxe, SWB, 2WD, 402, A/C. I developed an assembly kit for restoring the (a) truck from the ground up. My build thread, and more on the assembly kit https://67-72chevytrucks.com/vboard/...d.php?t=730025 |
05-07-2020, 06:02 PM | #2 |
Re: What's the deal with original bumper nuts?
Its a locking nut, the pressure on the non slotted side cocks the slots into the threads.
05-07-2020, 06:03 PM | #3 |
And yes used in the rear too. I think only on the bumper but not on the bracket to frame, i could be wrong on that though.
05-07-2020, 10:34 PM | #4 |
Thanks again Randy. I didn't think they were locking because I can screw them on by hand.
I think they were used for the rear bumper brackets as well. For bar bumpers anyway, I think HD bumpers used a different config. My C20 has those lock nuts for the front bumper brackets, on the frame side too. Per my notes my C10 did as well, but somehow I lost all but three off my C10, and and it bugs me....Less the front inner brackets, the assembly manual doesn't show lock washers for a front bumper or rear bumper bar, makes sense they'd use lock nuts instead. Hey man, for the serious builderhttps://www.mcmaster.com/self-lockin...type~flex-top/
Tony 71 Custom Deluxe, SWB, 2WD, 402, A/C. I developed an assembly kit for restoring the (a) truck from the ground up. My build thread, and more on the assembly kit https://67-72chevytrucks.com/vboard/...d.php?t=730025 Last edited by 71CHEVYSHORTBED402; 05-07-2020 at 11:48 PM. |
05-08-2020, 02:06 AM | #5 |
How is it they're always in the last place you look and the last place possible too? I looked high and low for these, thought to check an inventory of parts I had plated, yep, had eight plated, no sign of em. I put them in a box marked castle nuts
So I got 11, need 16, but that's what my C20 donor is for
05-08-2020, 06:59 AM | #6 |
Funny I just pulled the front bumper (68 C20) and thought, ..."that's odd they would use these nuts on the bumper".
Truck is from out west, and it was nice being able to pull the front fender, inner well and bumper off and no have to deal with one single rusty piece of hardware
'68 C20 Utility 396 4sp (BuildThread: http://67-72chevytrucks.com/vboard/s...d.php?t=806904 ) '68 C10 50th |
05-08-2020, 11:05 AM | #7 | |
My C20 came from near Pacific coast though. The body is a mess, but the rest mostly good.
05-08-2020, 12:44 PM | #8 | |
05-08-2020, 05:09 PM | #9 |
But Kevin, it's partially made of wood
05-08-2020, 08:53 PM | #10 |
Mesquite wood lol
...and when I'm done holding the truck together with it, I'm gonna put some in the smoker with the next batch of venison
05-08-2020, 08:58 PM | #11 |
Can't wait! Yum. I am overdue. Truck looks great. Just need to pain the a-arms.
05-09-2020, 10:41 AM | #12 |
Few places drier than Vegas and Az., your truck must be in great shape. Dumb luck on my part, everything popped right off for this novice less two shackle bolts. Only rust to speak of was a result of the battery, it destroyed the battery box. Luck has it the one in my rusted up C20 was still good. The core support might be better too, but I'm too lazy to pull it My 71 C10 had a top post battery, the 72 C20 a side post, coincidence? No, IMO.
05-09-2020, 11:47 AM | #13 |
Roto Reuter thats the name...
That's a great find. Especially for our area. I'm from the Buffalo area and I also found a great truck from Arizona. I stored it at a friend's house in the Phoenix area for a while then had it delivered here. It's on my 71 swb build thread (currently stalled). Can't wait to see what you're going to do with it.
~ Dan My 70 K10 SWB build:http://67-72chevytrucks.com/vboard/s...d.php?t=782232 My 71 SWB build:http://67-72chevytrucks.com/vboard/s...d.php?t=651394 1970 SWB Fleet K10 4X4, 5.3L LM7, 4L60E, Dakota Digital RTX, Vintage Air, Ididit tilt 1971 SWB Fleet C10 - Original SWB Arizona truck, new custom restoration project "Kick out your motor and drive while you're still alive - kick it out!" - Heart 1977 |
05-10-2020, 09:58 AM | #14 | |
05-10-2020, 03:26 PM | #15 | |
I got it here in NY this past November, just 'detailing', gonna leave the patina and drive it... Quick preview... Engine compartment before: After detail... Anyway, back to bumper nuts/bolts
