05-08-2020, 02:31 PM | #1 |
Preparing to order suspension parts, please review
Hey guys, i'm preparing to rebuild my suspension back to the control arms and convert to 4 wheel disk brakes, 5 lug. I've picked out everything I think I will need, listed below. I'm new at this and still learning. Would you guys be kind enough to look at everything i've got picked out and let me know if i'm missing anything or if there's anything I don't need or need to change?
Thanks for the help! 5 lug rear disk conversion kit: https://www.performanceonline.com/71...it-rear-5-lug/ 5 lug rear axle conversion kit: https://www.performanceonline.com/19...-Bolt-Pattern/ adjustable pan hard bar: https://www.performanceonline.com/19...-bar-trac-bar/ front and rear shock and drop spring kit: https://www.performanceonline.com/63...k-kit-csk0000/ tubular control arm kit: https://www.performanceonline.com/19...ntrol-arm-set/ coil spring retainer cup kit: https://www.performanceonline.com/19...-cup-kit-rear/ front sway bar kit: https://www.performanceonline.com/19...ormance-Front/ tie rod and idler arm kit: https://www.performanceonline.com/19...-Control-Arms/ pitman arm: https://www.performanceonline.com/19...ng-pitman-arm/ front disk brake conversion kit: https://www.performanceonline.com/19...le-5-or-6-Lug/ power brake booster kit, disk/disk: https://www.performanceonline.com/19...e-Booster-Kit/ I think this is everything I need? |
05-08-2020, 02:55 PM | #2 |
Re: Preparing to order suspension parts, please review
I don't know about POL, I would look at CPP. Every place has their shining sun. However I do hear that summit sells CPP and has free shipping so you can save some $$$.
I ordered from POL once, but that was only because they sold a true 1960 C10 front and rear sway bar. And for just the pitman and idler arm and ball joint type stuff, get Moog from Rock Auto.
"Work hard, use your vacation days." 1970 C15 GMC Long Bed 1986 C20 Scottsdale 1983 K2500 Sierra Classic Suburban 6.2 Instagram: C10sofOC |
05-08-2020, 03:20 PM | #3 |
My disc brake conversion is from POL (actually Western Chassis) and I'm happy with it.
The only thing I would change is to get the deluxe front disc conversion kit because it comes with inner and outer tie rod ends, adjuster sleeves, and upper and lower ball joints. I don't see ball joints listed in your post. You'll have to get the idler arm separate if you get the deluxe kit as it doesn't come with it. https://www.performanceonline.com/19...pindle-Deluxe/
1964 Chevy C10 - Gen IV 5.3 Restomod http://67-72chevytrucks.com/vboard/s...d.php?t=768632 1968 GMC C15 - Gen III 6.0 Restomod http://67-72chevytrucks.com/vboard/s...d.php?t=772047 1969 Chevy C10 - Restoration http://67-72chevytrucks.com/vboard/s...d.php?t=809184 1978 Chevy Scottsdale K20 1993 Chevy C1500 - 5.3/T56 swapped 2008 Silverado Duramax |
05-08-2020, 03:28 PM | #4 | |
05-08-2020, 03:29 PM | #5 | |
05-08-2020, 03:30 PM | #6 |
Then no, you don't need ball joints. You should be fine with everything you've got picked out.
05-11-2020, 09:27 AM | #7 |
05-11-2020, 04:55 PM | #8 |
I'm gonna throw this question out there. What is the intended goal for your truck?
05-11-2020, 05:40 PM | #9 | |
I just sold a corvette I owned so i've got about 16k to put in it. So far i'm thinking of redoing the entire suspension/brakes which is what the part list is above. Then nice tires/wheels to get the look i'm going for. The motor thats in it runs well now but it leaks and uses a LOT of oil and I like the idea of putting an LS in it, especially since i've got the money right now to do it. I'm thinking a 5.7 ls1. I can find a low miles motor and trans for around 4500. After that, i'm thinking whatever money i've got left i'd put in in the body/paint, interior. Am I way off base here? I'm open to any suggestions. Thanks for all the help so far. |
05-12-2020, 10:42 AM | #10 | ||
"I ain't nobody, dork."
Then you could save yourself a ton of cash and reuse the stock front control arms, stock rear trailing arms, keep drum brakes out back, get a 71-72 front 5-lug disc setup and get Moser 5-lug conversion axles.
You can get Moog suspension parts (ball joints, tie rod ends, etc.) at a local parts store. Unless you're autocrossing or building an ultimate show truck... you won't need all that fancy stuff. These rigs were designed pretty well from the factory. I also buy all CPP stuff from Summit Racing so I can get free shipping. Gary
'cuz chicks dig scars... My 1972 GMC 1500 Super Custom (Creeping Death) "long term" build thread. The Rebuild of Creeping Death after the wreck Quote:
05-12-2020, 10:55 AM | #11 | |
1967 C10 1980 Jeep CJ5 2020 Toyota 4Runner 2024 Toyota Tundra |
05-12-2020, 11:01 AM | #12 |
Agreed, you don't need rear discs or new front control arms. I rebuilt my rear drums and put new ball joints and cross shafts on my control arms and I'm happy. The front brakes do most of the stopping anyway so rear discs are just a luxury for a nice daily driver. Not much to gain with aftermarket control arms either for what you're building.
05-12-2020, 11:23 AM | #13 |
Thanks guys, definitely something to consider. The existing control arms and everything else on the suspension just looks so old and caked with dirt and 50 years of crap it just seemed like I should probably replace everything but maybe not..
05-12-2020, 01:03 PM | #14 | |||
I used the stock 1972 spindles and used CPP 2" lowering springs up front. I used the stock 1969 trailing arms and used CPP Heavy Duty 4" drop springs out back. Also used the stock 1969 panhard bar. CPP front and rear shocks with a shock relocation kit for the rear. Then I took it in for a front end alignment. Drives excellent, and looks cool as hell. Saved me a boatload of cash. Gary
05-13-2020, 11:29 AM | #15 |
I'm somewhere in between the suggestions. I took an afternoon with an angle grinder and some wire wheels to knock the grunge off, went with mostly stock replacement suspension components from Rock Auto, 2 1/2" drop spindles and a 6-lug 4-wheel disc kit. It works great for me and was budget friendly! I figured pictures might tell the story a bit better....
The process for the rear was the same. Clean, clean some more, inspect, paint, reassemble. It isn't a show truck suspension by any means, but it's a clean, reliable driver (suspension). (the rest of the truck isn't up to that standard yet.......but it stops better than my Camaro!)
1968 SWB Stepside "Bella coming home" "Bella's Build Thread" A master in the art of living draws no sharp distinction between his work and his play. He simply pursues his vision of excellence through whatever he is doing, and leaves others to determine whether he is working or playing. To himself, he always appears to be doing both. L. P. Jack |
05-13-2020, 11:50 AM | #16 | |
Just clean/paint/rebuild the control arms with Moog parts from RockAuto. As for the drop components, I suggest visiting www.azproperformance.com then call them. They'll put together a "package" with everything you want/need and take out any multiple items so you're not paying for stuff you don't need. For brakes, there's really no need in getting crazy with expensive setups unless you plan to drive angry in autocross/HPDE track days. The stock front disc brake setup is perfectly suitable for what you want. The right brake pads will determine how well it stops. You have to buy rear brakes to swap to 5 lug anyway, so rear discs are a good upgrade, even though you won't see any major gains over rear drums. On the engine, the 5.7L LS1 is great, but there's less expensive options. A truck 5.3 makes a great power platform and engine/trans combos can be found for as little as $1000 with low miles. You'd have to spend time shopping for that price or lower as average is around $1500-1800. A cam/valvetrain upgrade, headers and a good tune will yield about 400+ reliable HP.
05-13-2020, 04:38 PM | #17 |
My opinion on LSs. Thre great an all but the stock motor is just as reliable. Unless yours is buring oil or has seauros other issues why change it. Some will say that carbureted engines are hard to start when cold and bla bla bla. They can be yes. But 9 times out of ten it's not the carbs falut. It's the guy who thought he knew what he was doing fault. A properly tuned carb is very easy to start. ( stock engine ) but if that's what your issue is. You can put a tbi unit on it and all your worries will go away. Now if you want cheap HP the LS all day but a daily driver doesn't need 400+hp. This is my experience any way. Besides evey other c10 has a ls in it. Put a 2jz or something unexpected in one. Its to the point whare I'm surprised by an original sbc or i6. But if you want an LS I'm not going to stop you. This is just my opinion.
( second times the charm) 71 gmc c15 307 sbc 373 rear gears positrac sm 465 trans. ( not listed on spid but is original ) 94 chevy k1500 350 tbi 373 rear gears 4l60e one wheel peel. Gutless 07 gmc sierra classic rcsb 4.3 lt 5 speed w/t 04 chevy Silverado 1500 ext cab 5.3 4l60e. 81 chevy Scottsdale k10 muncie sm465 Np208 10 bolt 8.2 ( Old Green) |
