05-08-2020, 03:58 PM | #1 |
Dually front wheel conversion
I am not knowledgeable about duallys .
I want to put dually front wheels on a 1/2 ton for an upcoming project . What is involved in swapping them ? I have found a few parts vehicles and need to know what all front end parts to remove from the dually to install onto the 1/2 ton. Thanks I’m advance guys . 👍🏼 |
05-08-2020, 04:30 PM | #2 |
Re: Dually front wheel conversion
3 options
all custom work old school conversion kit from way back in the day or dana 60 front from a 1ton with DRW hubs on it . and if your talking 2 tires per side on the front the 10 bolt will NOT like that at all as the axle as a whole is not rated for anything close to that . and even the 60 front from a 1ton was not ment to be setup like that .
77-k30lb BIG truck build . 87-k30lb budget beater build . 85-k30lb the plow machine build . 85-c10sb summer fun toy . ----------------------------- HOLLEY SNIPER efi = worst case of p.i.t.a i ever had . EDELBROCK pro flo 4 = best deal going so far . love my setup works great. |
05-08-2020, 05:05 PM | #3 |
Post Whore
I'm guessing you mean 2wd instead of 4wd?...with a single front wheel from a dually on a 1/2 t
Like K30 said ..sounds like a lot of custom work...what's the plan ?. Are you just wanting 8lug rims for the front?...a 2wd dually has a really long extended hub... Not sure if the a-arms would "bolt on" to a 1/2t chassis...I'm betting not.. The easiest way would be do it from the a-arms out...complete assmebly... still would need fab work I'm betting.. I doubt the spindles would work on 1/2t a-arms... And the dually rotors wont fit the 1/2t spindles never seen anyone do it before And if the dually a-arms are longer than the 1/2t that may create more issues to swap from a-arms out. Some back story on what your wanting to accomplish would help...
Mongo...aka Greg RIP Dad RIP Jesse 1981 C30 LQ9 NV4500..http://67-72chevytrucks.com/vboard/s...d.php?t=753598 Mongos AD- LS3 TR6060...http://67-72chevytrucks.com/vboard/s...34#post8522334 Columbus..the 1957 IH 4x4...http://67-72chevytrucks.com/vboard/s...63#post8082563 2023 Chevy Z71..daily driver Last edited by mongocanfly; 05-08-2020 at 05:12 PM. |
05-08-2020, 05:21 PM | #4 |
Yeah I’m just asking about the front wheels , thanks for the reply’s so far
05-08-2020, 08:05 PM | #5 |
I actually just came across some adapters from southwest wheel out of Texas . Anyone heard of them ?
05-08-2020, 10:32 PM | #6 |
Post Whore
Could you link the specific one your looking at...I didnt see what i think your wanting..
Am I thinking right that you have a 5 lug rotor and want to mount a 8lug dually front wheel on it? So youd need a 5lug to 8lug adapter for a dual rim? https://www.southwestwheel.com/c-103...-adapters.aspx
05-08-2020, 10:43 PM | #7 |
The ball joints are different so you would need control arms out. Probably all the tie rods and steering as well.
SWW has been around forever. The dually adapters are 8 lug to 8 lug. If you are going with 22.5s the C30 brakes would be a big help.
1955 GMC 250 8 Flatbed 1971 C30 157" 350 4spd 10' Flatbed 81 GMC K30 CnC 9' Flatbed 454 T400 89 GMC Jimmy Stock https://67-72chevytrucks.com/vboard/...d.php?t=810958 71 LT1 Convertible, 72 Coupe 69 CJ5, 75 CJ6, 67 M715, 72 M35A2 Bobbed, 95 XLC2 |
05-08-2020, 10:46 PM | #8 |
05-09-2020, 02:11 AM | #9 |
Post Whore
Yeah..that's just a 8lug to 8lug spacer...
If you could somehow swap to 3/4t 8lug rotors with that spacer, it might work.. But I'm betting 3/4t rotors wont fit your spindles either...
Mongo...aka Greg RIP Dad RIP Jesse 1981 C30 LQ9 NV4500..http://67-72chevytrucks.com/vboard/s...d.php?t=753598 Mongos AD- LS3 TR6060...http://67-72chevytrucks.com/vboard/s...34#post8522334 Columbus..the 1957 IH 4x4...http://67-72chevytrucks.com/vboard/s...63#post8082563 2023 Chevy Z71..daily driver Last edited by mongocanfly; 05-09-2020 at 02:23 AM. |
05-09-2020, 02:17 AM | #10 |
Post Whore
You would need something like this ... https://www.ebay.com/i/173184791952?...oaAiuUEALw_wcB
And the spacer.... Personally I would never recommend running all that...to much going on... Way to many bad things can happen trying to use adapter/spacers..all that leverage tourqing on 5lugs isnt worth the liability
05-09-2020, 08:35 AM | #11 |
Thank you mangocanfly
05-09-2020, 12:39 PM | #12 |
just a heads up all the 1ton stuff is a LOT bigger and stronger even the frames .
so explain what you are trying to do and with what current parts ? then maybe we can help dial you in a bit better on whats needed .
05-09-2020, 10:46 PM | #13 |
It’s for appearance only , wants the look of a mini dually .
