Old 05-09-2020, 07:22 PM   #1
Bluegrain64
Hard cold start
Hello everyone, I’m having a cold start issue with my Rochester 1 barrel on a 235 six. It’s a manual choke set up and fires up with a hit of the key when it’s warm. If it sits for overnight or longer, it cranks like crazy and won’t start without a shot of fuel or carb cleaner.
I go through the regular cold start procedure as with all my carburetor equipped vehicles. Timing is good, points are new and set, carb was rebuilt and I run non-oxy fuel.
This cold no start is driving me crazy!!
I’ve attached a picture of my truck, it’s my favorite rig I’ve had.
Bluegrain64 is offline   Reply With Quote
Old 05-09-2020, 07:32 PM   #2
jayoldschool
Moderator
Re: Hard cold start
I just added a manual throttle cable/knob to my 65 and it makes a cold start much easier. However, have you verified your accelerator pump is working? I rebuilt the carb on my 65 to make sure that everything was working well.
jayoldschool is offline   Reply With Quote
Old 05-10-2020, 05:29 AM   #3
vince1
Re: Hard cold start
Beautiful prairie land you have out there and nice truck too.
If your fuel pump is good and the accelerator pump is good and your choke works good there is not much else except maybe put in an electric fuel pump, if just to get it primed. I'd try a fuel pump first though. It should prevent fuel from getting back to the tank.
vince1 is offline   Reply With Quote
Old 05-10-2020, 11:02 AM   #4
Bluegrain64
Re: Hard cold start
Thanks for the nice compliment on the property and truck. I’m going to check the accelerator pump shot today. I know the previous owner did put in a new fuel pump. It’s just weird how it fires up instantly with a hit of the key when it’s warm. I was reading too that there may not be adequate tension on the spring that goes over the accelerator pump rod and plunger.
I’ll take a look at the shot of fuel when it’s cold and report back.
Old 05-10-2020, 02:54 PM   #5
Bluegrain64
Re: Hard cold start
I checked the pump shot and I saw a pretty weak squirt. I could only see one, not sure if there are more? Did it a few times, and noticed it started to run out of the bottom of the carb near the base.
Old 05-10-2020, 03:25 PM   #6
geezer#99
geezer#99's Avatar
Re: Hard cold start
Sounds like you have enough fuel shot.
Maybe your starting procedure is at fault.
Are you the pump, pump pump the pedal until it sputters to life kinda guy or are you the two pumps and close the choke fully and poke the choke open a touch when she fires up kinda guy.
You might be flooding it if you’re the pump pump pump guy.
Old 05-10-2020, 04:05 PM   #7
Bluegrain64
Re: Hard cold start
😂 Ok I’m not going lie, I’m the pump, pump, pump, pump, pump, pump , pump close the choke, crank sputter, open choke, hold to the floor, pump some more sputter to life, hold throttle halfway until it clears out kinda guy.
If I do it the right way, it just sometimes briefly fires then dies right away.
Old 05-10-2020, 04:14 PM   #8
geezer#99
geezer#99's Avatar
Re: Hard cold start
Then give it one more pump and try again.
Is your choke blade fully closed when you try to start it?
Old 05-10-2020, 06:41 PM   #9
vince1
Re: Hard cold start
You could try changing the rubber hose coming from the tank to the line. If it has deteriorated it could be sucking air.
It happens more than you might think. I knew of a new Ford diesel that was hard to start. The guy that finally fixed it pressurized the line and found a pin hole leak.
Old 05-10-2020, 07:09 PM   #10
Bluegrain64
Re: Hard cold start
Yes it is, I know that for sure.
Old 05-10-2020, 07:24 PM   #11
PGSigns
PGSigns's Avatar
Re: Hard cold start
Here is something to try. First look at the fast idle setup. Push the pedal to the floor, then while it is down pull the choke. Pup the hood and take a look to see if the choke is closed and the fast idle is actually working. Then try and see if it will start. If you have fuel running out the throttle shaft you are flooding it. Start procedure should be push the pedal to the floor, pull the choke out about 80% and let up off the pedal. Hit the key and it should light. I think you are hitting it way to many ties.
Jimmy
60 to 66 Chevy and GMC window decals
http://67-72chevytrucks.com/vboard/s...d.php?t=661131
Good friends, good food and a hotrod what else do you need?
1966 BBW long fleet Daily driver
1965 BBW short fleet Sold and going to a good home
1965 Suburban
2003 3500 Duramax
2005 Ultra Classic
PGSigns is offline   Reply With Quote
Old 05-10-2020, 07:49 PM   #12
jayoldschool
Moderator
Re: Hard cold start
Wait, choke should be OFF when I pump it cold? THEN pull choke? I always pull choke when I shut off truck and start it the next time like that (still closed from last shutdown). Have I been doing it wrong? Could my truck actually be easier to start when it has sat for a few days?
Old 05-11-2020, 06:23 PM   #13
vince1
Re: Hard cold start
My technique for cold starting the 250 was this; full choke, pump pedal, crank a couple times, keep pumping, crank a couple more times and off she would go. The quadrajet on the SBC gets the same cold start procedure except that the choke happens by itself.
Old 05-11-2020, 07:22 PM   #14
franken
Re: Hard cold start
Maybe check the accelerator pump squirts when cold. I'm thinking the bowl is draining overnight and no gas in the AM. Sorry if I missed a post saying this was tried...
franken is online now   Reply With Quote
Old 05-11-2020, 10:01 PM   #15
Bluegrain64
Re: Hard cold start
Jimmy
Well I feel kinda dumb, but I tried the suggested method above yesterday and again today. It worked perfectly! I wasn’t doing the start process correctly. I was resorting back to my Quadrajet with no choke method. That required a lot of pumping and feathering and fiddling.
I pulled the choke, depressed the accelerator once, cranked and it fired/died. I then gave it one more shot of fuel with 3/4 choke and it fired right up! No more stabbing the gas pedal 20 times to start thinking it wasn’t getting enough fuel. I’ve got several old cars and they are all a little different for starting. Thanks everyone that offered their valuable insight. We’re good to go!
Old 05-13-2020, 11:34 AM   #16
jayoldschool
Moderator
Re: Hard cold start
I will try this today, and report back. My truck's been sitting for a week, and it has been below freezing each night. A good test. I need to use it tomorrow!
Old 05-13-2020, 05:07 PM   #17
jayoldschool
Moderator
Re: Hard cold start
Choke in, foot to floor. Pulled choke 3/4. Cracked throttle knob a bit. Started right up first crank. Who would have thought...
