Old 05-10-2020, 05:10 PM   #1
Jcfcamaro
Jcfcamaro's Avatar
Rain gutter
I'm planning on using 3m 08307 self leveling seam sealer on my 72 rain gutter/drip rail and was wanting some input on how many cartridges it will take.
Jcfcamaro is offline   Reply With Quote
Old 05-10-2020, 05:45 PM   #2
Biscuit240
Not familiar with what you’re using but I used a full calk gun cartridge of roofing sealer to fill mine. Don’t know if that helps.
Biscuit240 is offline   Reply With Quote
Old 05-11-2020, 01:32 AM   #3
toolboxchev
Re: Rain gutter
Was thinking of doing the same, don't know if its the same 3M number but the products that Napa had in stock it would take 2 most likely.
toolboxchev is offline   Reply With Quote
Old 05-11-2020, 09:05 AM   #4
HO455
Post Whore
HO455's Avatar
Re: Rain gutter
I only used one 200ml tube of SEM sealer on my Burban. So I believe one should be more than enough for a pickup.
RIP Bob Parks.
Old 05-11-2020, 08:25 PM   #5
dz1087
Re: Rain gutter
I used maybe 3/4 a tube when I did mine. Also sealed up the floor to firewall seam with the same tube.
dz1087 is offline   Reply With Quote
Old 05-11-2020, 10:26 PM   #6
70cst
70cst's Avatar
Re: Rain gutter
Great info...
A husband can be right...or...A husband can be happy.
67-72 Chevy and GMC Trucks...The Classic Truck for the Classic Folk.
1970 CST Two tone green, 402BB, 400 Automatic, Tach, Buckets, AC, AM-FM, Tilt, GM CB, GM 8 Tract, LWB, etc
JOHN 17:3...The better side of "LIFE"
Remember: Everyday is a good day...Some are just gooder!
70cst is offline   Reply With Quote
Old 05-12-2020, 10:34 AM   #7
GASoline71
"I ain't nobody, dork."
GASoline71's Avatar
Re: Rain gutter
I used the same 3M sealant for my gutter. I was a little over zealous and filled it probably too much. I used just a bit more than one double tube. Knowing what I know now, I could have done it with less than 1 double tube.
Gary
'cuz chicks dig scars...
My 1972 GMC 1500 Super Custom (Creeping Death) "long term" build thread.
The Rebuild of Creeping Death after the wreck
Originally Posted by LONGHAIR View Post
I would never rebuild a 305.
Originally Posted by prostreetC-10 View Post
I love using vacuum gauges as part of the carb tuning process. I hook the gauge to the inside of my garbage can and leave it there.
Originally Posted by Marv D View Post
Remember Murphys 2nd law of mechanical relationships... "OPPOSING COMPONENTS ATTEMPTING TO OCCUPY THE SAME SPACE, AT THE SAME TIME, GENERALLY END UP OCCUPYING ADJOINING SPACE AT THE BOTTOM OF THE OIL PAN"
Originally Posted by cableguy0 View Post
Its cheaper to listen to advice given when you ask for help than it is to ignore everyone and wait for carnage.
GASoline71 is offline   Reply With Quote
Old 05-12-2020, 11:03 AM   #8
hayhauler71
hayhauler71's Avatar
Re: Rain gutter
https://www.3m.com/3M/en_US/company-...3194150&rt=rud
This is the stuff i used per body shop recommendation. wont sag or run on vertical seam. Used 1 caulk tube
Fuzzy
hayhauler71 is offline   Reply With Quote
Old 05-12-2020, 12:24 PM   #9
Jcfcamaro
Jcfcamaro's Avatar
Re: Rain gutter
Gary
Seeing where the seem is verse the bottom of the gutter looks like to me I'll have to fill it up at least 1/8 so it will stay above the seam and hide the spot weld marks in the valley.
Old 05-12-2020, 12:49 PM   #10
GASoline71
GASoline71's Avatar
Re: Rain gutter
I jacked the rear end of my truck up as high as I could get it to help even out the flow along the front of the rail. So maybe I should have just did it with the wheels on the ground. Might have been able to not use as much to get the effect you describe above.
I will tell you this though. It sets up quick after it stops flowing. So any tape, paper or plastic masking stuff needs to be removed within about 2-3 minutes. I had a thing area of tape that got set up under the sealer and I had to go back over it to seal over the tape. Luckily it will be painted over and no one but me (and now you guys) will ever know.
Gary
