Old 05-11-2020, 09:04 AM   #1
44SAA
Air Cleaner Filter?
Hey Fellas-
Is there supposed to be a filter in the slot between the snorkel and the air cleaner?
44SAA is offline   Reply With Quote
Old 05-11-2020, 09:18 AM   #2
Ziegelsteinfaust
Re: Air Cleaner Filter?
yes, but it is not very necessary if checkbyour filter often enough. Then rotate once in awhile too.
Ziegelsteinfaust is offline   Reply With Quote
Old 05-11-2020, 11:10 AM   #3
Pontiac1976
Pontiac1976's Avatar
Not where you taken the pic that a bug & dirt deflector and helps air flow around carb suckion. I belevie as said there was pre-filter 85-up yr's but most do not replace them they leave them off.
1977 REG cab Long Bed with a 1984 Front Clip, 82 305 .60 over 9.0.1 flat top pistons, 4bbl, TH350, w/84 SS-intake & cam , w/ 1977 big block rad, 1975 gear box, 1984 master w/ metric fittings top & SAE fitting @ portion block, 1975 3.42 gear open diff. Duel 77-87 Factory air cleaner, duel inlet from rad support . Down sized 9' to new 8' Steel flat bed
Was a 77 454 w/308 gear. Taken out 550 lbs. up front with motor clip change.
Pontiac1976 is offline   Reply With Quote
