Old 05-11-2020, 12:05 PM   #1
dondb
Drive gear number for 3 speed saginaw?
I want to replace my driven gear on the 3 speed saginaw.....it leaks pretty good.
I see a lot of info about driven gears and was wondering if anyone knows the Drive Gear number for a 69 Saginaw 3 speed. I have 3.73 rear end gears and a 29.06 dia. tire. Trying to get a driven gear before i pull the old one out and thought maybe someone has that last piece of the formula??
Thanks for any help
1969 C-10 LWB SS
1969 Camaro Pro Tour
2002 Camaro SS LE Rag Top #937
dondb is offline   Reply With Quote
Old 05-11-2020, 12:35 PM   #2
LockDoc
The Older Generation
LockDoc's Avatar
Re: Drive gear number for 3 speed saginaw?
Thanks for any help
Trans parts
https://transmissioncenter.net/produ...dometer-gears/
Here is their calculator.
https://transmissioncenter.net/shop/...ar-calculator/
LockDoc
Leon
Old 05-11-2020, 01:13 PM   #3
geezer#99
geezer#99's Avatar
Just changing the gear might not cure the leak.
You likely need a new housing with a new outer and inner o-ring.
Here’s an example. I’m not sure which one fits your trans.
https://transmissioncenter.net/shop/...meter-housing/
geezer#99 is online now   Reply With Quote
Old 05-11-2020, 02:19 PM   #4
dondb
Thanks for the info. I called the shop that you linked the info to and they told me to go to ebay. Found a shop in California that sold the housing with inner and outer seals with 5 different driven gears for 21 bucks free shipping. I'll get back to this post after receiving and installation for a review.
1969 C-10 LWB SS
