Old 05-11-2020, 01:09 PM   #1
Cyanide93
1971 cheyenne stock build options
Im having trouble finding info on what exact options were available for a 71 cheyenne. Ill attach my build sheet if anyone can decipher it all. Did all cheyennes come two tone with a white stripe down the center or was solid color and white top available? Were the seat covers vinyl scroll letter only? Was there woodgrain on the dash bezel and glovebox? And were the door panels all vinyl with just the woodgrain strip? My dealer sheet shows "olive green, white top" im assuming like the photo attached.
1971 Cheyenne
350/700r4
Cyanide93 is offline   Reply With Quote
Old 05-11-2020, 01:15 PM   #2
jocko
jocko's Avatar
Re: 1971 cheyenne stock build options
Does your truck have a SPID inside the glovebox door? If yes, pls post it.
Your build sheet indicates the truck is indeed a Cheyenne (Z84 Custom Sport Truck=Cheyenne starting in 1971)
Cheyennes could come in any solid or two tone combo (conventional, deluxe (what you described with white down sides) or custom (non-whites).
Truck in pic is painted correctly for the build sheet code of 534 - i.e. conventional two tone 521 white over 504 medium olive)
Yes, vinyl with scroll only for bench seats.
No woodgrain on dash or gb - door panels and lower trim and tailgate only.
Old 05-11-2020, 01:26 PM   #3
Cyanide93
Absolutely, here you go. Thank you very much for that info.
1971 Cheyenne
350/700r4
