05-11-2020, 02:50 PM | #1 |
Roto Reuter thats the name...
Anyone have a lead on aftermarket differential covers
I'm looking for a decent set of aftermarket aluminum front and rear differential covers for my 70 K10. Anyone have an idea where I can get a matched set?
The front axle is the one year only open knuckle Dana 44, 10-bolt The rear axle is the GM truck 12-bolt (I believe 8.875") For the life of me I've never been able to get them to stop leaking. I've tried several times. Gasket... No gasket... Black RTV sealant... Cleaned vent tubes. Nothing seems to work. I'm wondering if a heavier flanged differential cover would make a difference. I'm getting tired of trying. Your thoughts are welcome. Front cover, Dana-44 Rear cover, 12-bolt design
~ Dan My 70 K10 SWB build:http://67-72chevytrucks.com/vboard/s...d.php?t=782232 My 71 SWB build:http://67-72chevytrucks.com/vboard/s...d.php?t=651394 1970 SWB Fleet K10 4X4, 5.3L LM7, 4L60E, Dakota Digital RTX, Vintage Air, Ididit tilt 1971 SWB Fleet C10 - Original SWB Arizona truck, new custom restoration project "Kick out your motor and drive while you're still alive - kick it out!" - Heart 1977 |
05-11-2020, 03:55 PM | #2 |
Re: Anyone have a lead on aftermarket differential covers
Have you tried Lube Locker gaskets? Many people swear by them.
I'm running Ruffstuff covers on mine, which are awesome, but it doesn't look like they have a 12 bolt version. |
05-11-2020, 04:56 PM | #3 |
I looked at Ruffstuff, and you're correct. No 12-bolt version.
05-11-2020, 07:33 PM | #4 |
10 and 12 bolt covers in HD steel off road use are kind of hard to find . it think it has to lend to there shape .
but easy search shows china to t/a to lpw and other name brands in good covers . searched ebay with dana 44 aluminum cover and chevy 12 bolt truck aluminum cover and got a lot of hits . i used a TA brand 12 bolt truck cover a few years ago on my 2wd build . i have yet to run the truck . but with thin film of sealer on both sides of the gasket and full of oil no leaks yet in the parking spot its at for now .
77-k30lb BIG truck build . 87-k30lb budget beater build . 85-k30lb the plow machine build . 85-c10sb summer fun toy . ----------------------------- HOLLEY SNIPER efi = worst case of p.i.t.a i ever had . EDELBROCK pro flo 4 = best deal going so far . love my setup works great. Last edited by sweetk30; 05-11-2020 at 07:38 PM. |
05-11-2020, 07:58 PM | #5 |
summitracing.com
05-11-2020, 09:56 PM | #6 |
I hear you guys. I got quite a few hits on internet searches. I was just looking to see what others may have used. I was looking at Summit and may go with their brand since I don't need "high end" covers for my build. Thanks for taking the time to comment.
05-11-2020, 11:56 PM | #7 |
"The front axle is the one year only open knuckle Dana 44, 10-bolt"??????
What is different about the 70 from the rest of the open knuckle 44s?
1955 GMC 250 8 Flatbed 1971 C30 157" 350 4spd 10' Flatbed 81 GMC K30 CnC 9' Flatbed 454 T400 89 GMC Jimmy Stock https://67-72chevytrucks.com/vboard/...d.php?t=810958 71 LT1 Convertible, 72 Coupe 69 CJ5, 75 CJ6, 67 M715, 72 M35A2 Bobbed, 95 XLC2 |
05-12-2020, 08:37 AM | #8 |
All about them K’s
70 is the only year for red hub dials and open knuckles with drum brakes.
Tyler '57 3100 http://67-72chevytrucks.com/vboard/s...d.php?t=813888 '72 K20 Cheyenne: 5” lift, 35’s, front dana 60 blah blah blah… http://67-72chevytrucks.com/vboard/s...d.php?t=662879 ‘69 K10 SWB: 4” lift 33”s… in a million pieces http://67-72chevytrucks.com/vboard/s...d.php?t=805206 '98 Silverado LT K2500HD ECLB Vortec 454/4l80E: 6" lift 35x12.5x20’s |
05-12-2020, 11:50 AM | #9 |
my dad had a late 69 or early 70 GMC K2500 sbc/465/205/4.56-power-lok posi truck with 44 front open and drum brakes with brass dial warn hubs .
77-k30lb BIG truck build . 87-k30lb budget beater build . 85-k30lb the plow machine build . 85-c10sb summer fun toy . ----------------------------- HOLLEY SNIPER efi = worst case of p.i.t.a i ever had . EDELBROCK pro flo 4 = best deal going so far . love my setup works great. |
05-12-2020, 07:46 PM | #10 |
I have finned aluminum covers on my '72 K2500. I found a used Dana 60 cover, then bought a shiny new Dana 44 cover off Ebay. To match it up to the old rear cover I dropped the shiny new one in a bucket with muriatic acid. Put a nice tarnish on it. I know I have seen 12-bolt covers like that, but have never needed one. I considered one for my little '67 2wd but figured the panhard bar wouldn't clear. Not a concern with a K/10 or leaf spring C/10. I remember a thread where we discussed the clearance issue
05-13-2020, 08:36 AM | #11 |
Your 12 bolt rear cover has been lipped and that bends the sealing flange which is why you can't get it to seal up. My A1 rear was destroyed by a lipped cover that someone was driving in 4 wheel drive until all the pinion teeth peeled right off the pinion from heat.
The front Dana 44 cover is extra thick and it should be easy to get it to seal. A paper Fel-Pro gasket and brush Aviation Form-A-Gasket on both sides after making sure all surfaces are clean. The Gale Banks diff cover tests on YouTube show the flat back diff covers don't work as well as the OEM ones. A nice used cover from a 2x4 that has not suffered the ravages of the rocks should seal up as well on the rear.
05-13-2020, 09:04 AM | #12 |
I used Alien machine worx. Very nice, powder coated
To your color. I got a matching 14 bolt rear, and a Dana 60 front. They are reasonable, and Rock solid. They Come with bolts. I suggest lube locker as well. |
05-15-2020, 08:26 PM | #13 |
Looking closer at my front Dana 44, it appears that the leaking may not be from the cover, but at the driveshaft. It looks like there must be some seal where the drive shaft is mounted, and it is leaking and running down toward the cover then dripping. Not sure how to address this now?
12-bolt rear is definitely leaking at the cover.
05-15-2020, 10:24 PM | #14 | |
All about them K’s
05-15-2020, 10:32 PM | #15 | |
05-15-2020, 10:34 PM | #16 |
All about them K’s
No problem, Yea your local parts place should have them, or be able to get them easily.
05-18-2020, 09:23 AM | #17 |
My Dana 44 leaked from the splines of the yoke. I think there is a seal for that but silicone works. Mine also leaks from the tube/housing connection. I've been too lazy to attempt to fix.
My Classics: '72 K20 Suburban + '65 Dodge Town Wagon '72 Corvette Roadster +'67 Corvette Roadster '73 Z-28 Camaro '63 Ford SWB Uni Pickup '50 Ford Coupe |
