Old 05-11-2020, 03:57 PM   #1
demian5
demian5's Avatar
Horn stuck on
I have a 1970 with a factory column and square body wheel. I pulled the horn cap and the spring and contact but the horn stays on. Anyone have any ideas to look for when I pull the wheel? Only option seems to be a short in the wire in the column. Turn signals work fine BTW. Its a non-tilt column.
"Work hard, use your vacation days."
1970 C15 GMC Long Bed
1986 C20 Scottsdale
1983 K2500 Sierra Classic Suburban 6.2
Instagram: C10sofOC
demian5 is offline   Reply With Quote
Old 05-11-2020, 04:54 PM   #2
LockDoc
The Older Generation
LockDoc's Avatar
Re: Horn stuck on
How about a little background on the problem, when did it start, what if anything has changed on the truck.... etc., Throw us a bone here.
LockDoc
Leon
Old 05-11-2020, 05:06 PM   #3
truckster
truckster's Avatar
Re: Horn stuck on
There's a relay between the horn button and the horn. Pull the relay and hook up a test light - your neighbors will thank me.
I have sworn upon the altar of God, eternal hostility against every form of tyranny over the mind of man. - Thomas Jefferson
truckster is offline   Reply With Quote
Old 05-11-2020, 07:17 PM   #4
demian5
demian5's Avatar
Re: Horn stuck on
Ok - So I got the truck with the horn unplugged and the battery dying.
I unplugged the relay and now the battery doesn't die anymore, but I want to fix the horn. The relay clicks when its plugged in and unplugged.
I removed the horn button and the contacts from the wheel. That didn't work, still stuck on.
That's the background.
1986 C20 Scottsdale
Instagram: C10sofOC
Old 05-11-2020, 07:27 PM   #5
kwmech
Re: Horn stuck on
You either have a stuck relay or a short to ground inside the column. Unplug the turn signal harness then plug the relay in again
Old 05-11-2020, 07:28 PM   #6
franken
Re: Horn stuck on
Trace the wire that activates the relay to where it's getting grounded. Sounds like it might be flopping around under the wheel, or things aren't put together right in the column to make the horn work. It can be a puzzle.
franken is offline   Reply With Quote
Old 05-12-2020, 01:19 PM   #7
demian5
demian5's Avatar
Fixed!
Got it fixed.
The retainer on the replacement turn signal switch that holds the spring in for the horn contact, it would touch the column bearing housing and stay grounded when you pressed the horn. Filed it down and it is all good.
1986 C20 Scottsdale
Instagram: C10sofOC
Old 05-12-2020, 11:38 PM   #8
saxart
saxart's Avatar
Re: Horn stuck on
Just saw this post. Is this what happened to yours?
http://67-72chevytrucks.com/vboard/s...d.php?t=765275
Meet "Old Roy": http://67-72chevytrucks.com/vboard/s...d.php?t=707801
saxart is offline   Reply With Quote
Old 05-16-2020, 08:20 AM   #9
Bearhawg
Bearhawg's Avatar
Re: Horn stuck on
SAXART, I can’t thank you enough for posting this link. My problem was exactly what is related in this link. Two or three minutes of grinding back that small metal plate and it immediately resolved the issue. I have been chasing this gremlin for months.
This forum is an amazing resource. Posts by fellow members have saved me endless amounts of frustration.
Thank you!!
Bearhawg is offline   Reply With Quote
