steering column upgrade
bought a 1978 c-10 in pieces. The seller was bragging about how he was giving me a upgraded tilt steering column out of a 89 suburban. Just installed it in car and it looks way to long between the dash and the seat . Anyone know if this column would be longer??? Thanks
![]() Join Date: Aug 2018
Re: steering column upgrade
I don't know much about square bodies. But if it has the same style connection between the section that attaches to the rag joint and the rest of the column, you can melt the plastic out of that joint, slide that connection in (to shorten the overall length), drill two new holes, and bolt it back together. That's what I did as my column was longer than I wanted.
1964 Chevy C10 - Gen IV 5.3 Restomod http://67-72chevytrucks.com/vboard/s...d.php?t=768632 1968 GMC C15 - Gen III 6.0 Restomod http://67-72chevytrucks.com/vboard/s...d.php?t=772047 1969 Chevy C10 - Restoration http://67-72chevytrucks.com/vboard/s...d.php?t=809184 1978 Chevy Scottsdale K20 1993 Chevy C1500 - 5.3/T56 swapped 2008 Silverado Duramax |
#3 | |
![]() Join Date: Sep 2005
thats what i did was melt the plastic and collapse the intermitt shaft but i did not bolt it back together as it is ment to collapse incase of an accident
David fuller Ase Certified Mechanic Click here to help support our board!! 1971 Chevy c-10 under going a 4.8l LSx swap Build Thread http://67-72chevytrucks.com/vboard/s...d.php?t=421305 2015 toyota Tacoma Daily 2012 Subura outback 2000 Tahoe 5.3l 420k 1999 honda accord General manager for Marco's Carwash & lube |
I like the idea . One question . I am guessing some fab has to be done on the attaching bracket where it bots to the dash.
![]() Join Date: Jun 2015
One thing to note: 78 has dash mounted wiper switch and floor mounted headlight dimmer. The 89 column will have all that on the turn signal stalk.
Jay Gesner Atlanta, GA 1985 C10 Long Bed 4X2 LS 5.3, 4L60E Father/Daughter Project |
agree I will may one or the other work depending on the new wiring harness that I buy
#7 | |
BMW & ASE Master Certified
I also have a picture or 2 on my imageshack account that shows one of the mods needed to accomplish it. once the steering wheel is reinstalled, ill update with pictures. clint
1987 Silverado - L83 5.3 w/ 6L80e ,A/C,P/W,P/L,TILT, HID projectors, Wilwood C-10 Pro Spindles w/ 2018 silverado front brakes & C-5 Corvette Rear Disc Brakes 1999 BMW 528i - 5.7 LS1 w/ 4l60e, Ford 8.8 IRS w31 spline posi & FX-r projector retrofit New project: 2006 BMW x5 6cyl AWD to L83 6l80e 4wd to 2WD / RWD A poor man buy's it twice finally got my domain name back, 87chevy.com.... site rework in progress |
I got mine to slide in 3 inches by removing the lower switch on the column which is a switch that tells what gear you are in and then drilling two hole in the brake bracket 3 inches down (have to fab a small notch on one side) from where the originals are and welding studs in the holes. Now the column looks good. Only challenge is do I need the switch I removed. I am thinking it is only for a dash light to tell me what gear I am in or to only let it start in park. I will figure out a solution for this.
#9 | |
other switch is park neutral so, no switches = no reverse lights or park neutral unless you wire in the 4L60e park neutral switch properly which no engine swap pallet people do ever heres the pictures I found when I did this mod 7 years or more ago: simply cut out a section, dont go to deep, just cutting the tube off ![]() picture shows the new rectangle shaped notch in the 2nd tube for the park neutral / reverse light switch ![]() took the piece of colum i just cut out and cut it in half and swapped locations. tacked them together and placed over column to get the new location for the park neutral / reverse switch hole location. welded up ![]() also recommend getting a new steering column bearing at the end / engine side from a jeep wrangler, Omix-Ada 18019.03 is better than the Crown brand. and the jeep wrangler steering shaft. its cheaper than the Cherokee, has the same fittings as the Cherokee but is about a foot longer, once shortened direct bolt in, just need to add a rivet to the column shaft to act as the notch some people talk about it needing. The wrangler version I bought did not require the steering column shaft to be notched for the bolt to pass through. I wound up adding a small washer and a rivet between the end of the shaft and where the pinch bolt is so if it became loose, it couldn't slide off (because the rivet head would stop it. shaft at column showing rivet and washer to get the right height. ![]() gearbox side ![]() clint
1987 Silverado - L83 5.3 w/ 6L80e ,A/C,P/W,P/L,TILT, HID projectors, Wilwood C-10 Pro Spindles w/ 2018 silverado front brakes & C-5 Corvette Rear Disc Brakes 1999 BMW 528i - 5.7 LS1 w/ 4l60e, Ford 8.8 IRS w31 spline posi & FX-r projector retrofit New project: 2006 BMW x5 6cyl AWD to L83 6l80e 4wd to 2WD / RWD A poor man buy's it twice finally got my domain name back, 87chevy.com.... site rework in progress Last edited by 87chevy.com; 05-16-2020 at 06:21 PM. |
I am impressed. I will do this to mine . Thank You it will make my project that much better. Thanks again some of that Houston Proud ingenuity
what year jeep wrangler |
#11 | |
Clint
I am using a 89 column it has a different connecter then a 78 the 89 has a oval type looking connection on column shaft. The 78 is a perfect circle with spines. Do you remember what he jeep is . Thanks
#13 |
update. just finished the job of moving the column switch. A little tricky since I cant weld very good but overall straight forward. Ordered a new lower bearing per the info above. Interesting it shows it to fit a wrangler but no where could I find one to fit my 89 suburban column. Goes to show good to ask on this forum.. Thanks again it was a big help
#14 | |
So, I scooted the pedal over the thickness of a cylinder head washer.. maybe 1/4-3/16. I'll take a picture but there's I though of 2 ways it could be done. one, requires welding, but it needs to be solid weld, since its brake pedal pivot mounting point. or two, take it to a machine shop and have them mill off what ever thickness of washer you provide on the pedal and spacer. I almost was gonna take it to the machine shop, although its a easy job, its still gonna cost 50-100 for their time and tools. Itching to get it back together then onto other upgrades. clint
| Bookmarks |
