05-12-2020, 01:33 PM | #1 |
Drop set ups and wheel combos!!
Good morning everyone !
I Have a 1980 c10 and want for ideas in lowering my truck. I would like a leveled drop or a drop and wheel combo that will make the fender sit as close as possible to the wheel and not hide any behind the fender. I currently have a big rake that I don’t like . I’m running belltech 3120 from 71-72 trucks and pretty much stuck with that since that’s how I got the truck and don’t have the money to change them. I don’t know if they cut the springs but I’m pretty low in the front . I have long tube headers with 5in clearance and don’t want to do too low. I was thinking of just buying replacement front springs to raise the front and be at just 3in drop. I was thinking of shackles and hangers from belltech in the back since the truck came with shackles and unfortunately cut a big section of the bed frame. I’m running 255/60/15 in the front and 275/60/15 in the rear. I love side walls so the biggest I will get is 17 or 18 in wheels and maybe 50 series . Any pictures of drops and wheel combos will be a big help. I understand this question has been asked but I would like to see new pictures of members who are still active and not a post from a decade ago. I will post a truck I saw on the forum. I love the stance and that’s something I would like! Thank you! |
05-12-2020, 03:30 PM | #2 |
Re: Drop set ups and wheel combos!!
4/5 drop. 15x8 and 15x10's, 245/60 and 295/50 TA's
05-12-2020, 03:48 PM | #3 |
05-12-2020, 03:54 PM | #4 |
And I looked up the sizes for your tire and you are running the same height even tho one is 50 and the other is 60 . That’s why you have a nice leveled drop! I need to find same height tires for all 4 corners and replace the different height of the 255/60 and 275/60!
05-12-2020, 04:09 PM | #5 |
Flip kit on the rear.
05-13-2020, 04:28 PM | #6 | |
50's, 60's, 70's series are just the sidewall ratio of the tire width. You can mathematically have several different combos that all yield a similar overall height.
67SWB-B.B.RetroRod 64SWB-Recycle 89CCDually-Driver/Tow Truck 99CCSWB Driver All Fleetsides @rattlecankustoms in IG Building a small, high rpm engine with the perfect bore, stroke and rod ratio is very impressive. It's like a highly skilled Morrocan sword fighter with a Damascus Steel Scimitar..... Cubic inches is like Indiana Jones with a cheap pistol. Last edited by SCOTI; 05-13-2020 at 04:38 PM. |
05-13-2020, 04:50 PM | #7 | |
05-15-2020, 08:36 AM | #8 |
I run the same set up as Loco pretty much. This picture is 2.5" drop spindles and 2" drop springs in the front and a rear flip kit with 5 leaf packs.
Front is 15x8 with 4" BS and 245/60/15. Rears are 15x10 with 5" BS and 295/50/15. The front is a little too low for me so I have some 1" drop springs coming in today.
Mike 1976 C10 RCLB - 350 - SM465 4 Spd - 4.5"/6" Drop Obligatory Build Thread HERE! 1979 C20 RCLB - 350 - TH350 Auto |
05-15-2020, 08:55 AM | #9 | |
05-15-2020, 08:56 AM | #10 | |
05-15-2020, 06:56 PM | #11 | |
I didn't measure but I would say it went a full 6". My truck has the longer leaf packs of the two and had 8-leaf packs from factory. My original plan was to ditch all but three plus the overloads but I found both packs had multiple cracked leafs and it forced my hand. I was fortunate and found some 5 leaf packs from a Suburban locally for a deal. I did not c-notch but I also do not work the truck very hard. I've hauled 400 pounds of deer corn and did not have any issues and I never even looked at what clearance I had... I've never had a lowered truck before this one so I went all in (static anyway) and do not regret it at all. You have to be a little more careful when driving since the LCA's hang really low but it's not too bad once you get an eye for it. I knew if I didn't do it the way I did I would regret it and end up doing it over.
05-15-2020, 08:40 PM | #12 | |
I really with I would have gone with a flip kit. I wasnt going for more than 4 inches at the time so I did shackles and hangers then scrapped the stock parts. Now I want just another inch or so out back. I am considering removing the overload leaf and rolling with 3 leafs. Also should get some drop shocks it's on factory length right now
- When the Reaper makes his deal, trust in your steel - '77 C10 350/350 2/4 drop and a mild street engine |
05-15-2020, 09:47 PM | #13 | |
the c notch is tricky. some do it and some don't. Glad you didn't have to c notch the frame and still be able to haul a lot of weight with no issue. That was my main issue that i didn't want a flip kit to avoid c notch. |
05-15-2020, 09:48 PM | #14 | |
05-15-2020, 10:38 PM | #15 |
Prepare for an eye sore
Western Chassis parts 2 1/2" drop spindles 2" shackles 2" hangers 15x7 front 205/60/15 15x10 rear 295/50/15 Both front and rear are 4.5" backspacing I really want to drop front and rear one inch.
05-16-2020, 01:11 AM | #16 |
bro thats one badass truck and stance! you had the drop I wanted to all this time lol.. I want a leveled drop and I think ill be going for 3 / 4 drop since I have the 3in spindles. im afraid if I do a flip kit ill get 6in drop and it will be a reversed rake lol. a 3 / 4 is close enough plus ill be running taller tires too to fill up the fender hopefully. Thanks bro! I just hope it looks like yours and hope the difference in beds dont affect it
05-16-2020, 07:09 AM | #17 |
Thanks man I appreciate it.
When you do the shackles and hangers, taking the bed off makes it pretty easy. You will need to notch one of the beds crossmembers above the shackle so mark it before you remove the bed and you'll be good to go.
05-16-2020, 09:14 AM | #18 | |
3/8" allen head bolt is what you'll need to bolt it back together, about 2" if I recall.
05-16-2020, 10:01 AM | #19 | |
05-16-2020, 02:53 PM | #20 |
Not always. The trucks w/the shorter 52" leaf springs require the bed support to be clearance. Trucks w/the longer 56" spring don't require it.
05-16-2020, 03:06 PM | #21 |
Ah yes I forgot about that.
05-16-2020, 03:16 PM | #22 |
But.... You are 100% correct about marking things before taking them apart. It gives you the outline for the cuts whether you need them or not.
05-16-2020, 07:05 PM | #23 | |
I have used this tire size calculator many many times. It's interesting to mess around with different sizes and how they compare https://www.tacomaworld.com/tirecalc
05-16-2020, 09:03 PM | #24 | |
I do use online calculators for gearing decisions, number crunching engine combos, CID's, & power output potential. Very handy tools.
05-18-2020, 01:52 PM | #25 | |
Just got the US Wheel Rat Rods. Do you think with a 295/50 and 4" BS it will stick out too far? Or should I go to the 275/60 which would be about the same . I want 295s in the back but don't want them to stick out way far. Last edited by techsan40; 05-18-2020 at 02:51 PM. |
