05-12-2020, 02:00 PM | #1 |
TH400 vacuum line
After searching many a thread for an answer, I can't seem to get confidence around finding the correct steel vac line for a '68 327/TH400. Can anyone show me some pics, especially ones that capture the top end of the line and how/where it ends and transitions into a rubber vac hose?
I've also been shopping for a new one from an aftermarket supplier, but nobody's application guide seems to list parts for a '68ish GM pickup. Wouldn't one from a car in this era work OK? ...but they have many different part numbers for the different GM cars in these years, so maybe not? Can anyone give me a part number that will work for my pickup?
Ben '68 Chevy C10 Custom LWB 327/TH400 2nd owner '16 GMC Sierra 1500 SLE Dblcab 4wd 5.3 |
05-12-2020, 02:35 PM | #2 |
Re: TH400 vacuum line
Maybe check one out for a 1968 Impala/Caprice,the there is some extra room on a Impala,my old 68 was a 327/300 hp with a Turbo 400 amd i remember there was room,Try Modern Chevrolet in Winston-Salem,NC I used to buy a lot of parts from them,I just checked,Ecklers has them for Chevelles,28.00
05-12-2020, 04:09 PM | #3 |
I can't help with a source, but here are some pictures of my '69 with a 350 and TH400. The "clean" pictures show the original line on my GM 350 crate engine and Holley carb. The "dirty" pics are the installation with the original 350. The line runs to a "T" on the intake behind the carb along with vacuum lines for the power brakes and A/C vacuum line (if so equipped). I don't know if the 327 would be similar.
Jim Last edited by FirstOwner69; 05-12-2020 at 04:23 PM. |
05-12-2020, 05:06 PM | #4 |
Yes
"Work hard, use your vacation days." 1970 C15 GMC Long Bed 1986 C20 Scottsdale 1983 K2500 Sierra Classic Suburban 6.2 Instagram: C10sofOC |
05-12-2020, 05:35 PM | #5 |
$28.00 + shipping for a "pre-bent piece of tubing?? Have you tried bending your own for 5 bux or less?? the line runs basically from a fitting on the intake manifold, down the bell housing area and connects to the modulator valve via rubber tubing..
05-12-2020, 05:49 PM | #6 |
Thanks for the pics and the suggestions. The pics make it easier to see what the right one should look like. They also make me think I should take a stab at bending my own before I decide to pay for a pre-bent one.
How critical is it that the ends be made like the factory lines were? Is it a good alternative to slide a vac hose over a cut end and use a hose clamp?
05-12-2020, 05:54 PM | #7 |
Classic Industries carries the line for 69-70 but not 67-68 and 71-72. That implies the lines may differ. Note the ends of the line are unique (smaller). I don't know if there would be a reason other than properly attaching the lines at each end with the short pieces of rubber hose.
https://www.classicindustries.com/sh...0vacuum%20line
Jim |
05-12-2020, 06:06 PM | #8 |
Classic Industries shows this one part number fits both TH400 and TH350? Aren’t the modulators in very different places on those two transmissions?
05-12-2020, 06:10 PM | #9 |
Who Changed This?
You can make your own, yes. What I do in this case is make a bulge in the end of the tube by making the start of an inverted flare on the end of the tube. If you have a line flaring tool kit, you can see what that looks like. The bulge, properly made, will keep the hose on the tube without an unsightly clamp.
05-12-2020, 06:51 PM | #10 |
The Right Stuff obviously makes what Classic Industries sells (same part number). Also says TH350 and TH400.
https://www.getdiscbrakes.com/ttv6905
Jim |
05-12-2020, 07:13 PM | #11 |
Post Whore
I've got one. It is pretty crusty but doesn't seem to be mangled up. If your interested I can send it your way.
Thanks to Bob and Jeanie and everyone else at Superior Performance for all their great help. RIP Bob Parks. 1967 Burban (the WMB),1988 S10 Blazer (the Stink10 II),1969 GTO (the Goat), 1970 Javelin, 1952 F2 Ford OHC six 4X4, 29 Model A, 72 Firebird (the DBP Bird). 85 Alfa Romeo If it breaks I didn't want it in the first place The WMB repair thread http://67-72chevytrucks.com/vboard/s...d.php?t=698377 |
05-12-2020, 07:18 PM | #12 |
At the body shop.
Buy an extra elbow on the transmission side.
The new rubber doesn't hold up like it used to. And creates and vacuum leak and your trans won't shift too well.
" That didnt make it any newer " " Dont antique the equipment " |
05-13-2020, 08:33 AM | #13 |
The original vacuum line has a tab on it so that it can be bolted securely to trans.
Not that original, off by a tab. NGN |
05-13-2020, 08:43 AM | #14 |
Post Whore
????? Where does the elbow go?
05-13-2020, 12:00 PM | #15 |
At the body shop.
Mine has an adjustable modulator, the nipple sticks out 90° to yours.
And has a elbow in the vacuum line
05-13-2020, 12:53 PM | #16 | |
Sounds like your modulator was replaced. I don't believe GM used an adjustable version. Do you have a picture of the transmission attachment point?
Jim |
05-13-2020, 12:58 PM | #17 |
I mentioned earlier that the ends of the original line are a reduced diameter. As I recall this allows the ends of the line to fit inside the barbs on the manifold fitting and modulator. I've guessing this is to prevent the rubber hose pieces from collapsing under vacuum.
Jim |
05-13-2020, 01:39 PM | #18 |
At the body shop.
After seeing the one posted.
I'm sure it's not stock. But both of my th400s have them. And recently had a rotten vacuum hose cause some headaches.
07-05-2020, 05:07 PM | #19 |
maybe a dumb question but I'll ask anyway...
Anybody ever tried to run the line as a rubber hose from the intake manifold all the way down to the modulator at the trans? That's what I did and now she won't shift into 3rd. Do you guys think the rubber hose the culprit? Should I switch it out for a steel tube? |
07-05-2020, 08:37 PM | #20 |
Inline tube sells the correct vac line in SS for $35.00. If you go on line you can look at it and probably make your own. #SCTT7104
07-05-2020, 09:36 PM | #21 | |
07-05-2020, 10:42 PM | #22 | |
Who Changed This?
