Old 05-13-2020, 08:51 PM   #1
44SAA
Gonna be Fuel in my Hair
It’s time to replace these 40yr old hoses. Is there a clever way to do this without spilling fuel on my face?
44SAA is offline   Reply With Quote
Old 05-13-2020, 11:27 PM   #2
Dead Parrot
Re: Gonna be Fuel in my Hair
Not that I have found. Some benefit to raising the rear end so you have extra room to be off to the side a bit. A few layers of 2x6 can do the trick. Even if it doesn't leak when you first loosen the clamps, it will often drain gas the moment you lower one end of a hose.
Dead Parrot is offline   Reply With Quote
Old 05-14-2020, 12:11 AM   #3
mongocanfly
Post Whore
mongocanfly's Avatar
I have a set of these hose cutters...you can reach way out and cut the hose between the clamps and let it drain out...
Mongo...aka Greg
RIP Dad
RIP Jesse
2023 Chevy Z71..daily driver
Old 05-15-2020, 09:53 AM   #4
v30crewcab
v30crewcab's Avatar
needle nose vise grips clamped on the feed line will help. take your clamp loose, then take some pliers and twist them sideways to break the connection, spray a little pb blaster in the edge and they'll usually pop right off. can also cut the hose lengthwise with a razor blade but be careful on the plastic nipples.
88 military v30 crewcab shortbed 5.9 cummins, nv4500, 205
86 k30, 89 diesel burb, 76 gmc pathfinder
71 longbed 5.3 4l80
http://67-72chevytrucks.com/vboard/s...d.php?t=522535
v30crewcab is offline   Reply With Quote
Old 05-15-2020, 01:35 PM   #5
Killer Bee
Killer Bee's Avatar
no, no, no...
get a few pairs of hose pinchers in the sizes you need and never look back!
