05-15-2020, 11:46 AM | #1 |
Rear End Swap
I have a 67 C10 Stepside that needs new rear end. i happen to have a 1970 Suburban rear end. they appear the same. would there be any reason they will not be direct swap?
also, what was factory gear ratio for a 70 suburban? |
05-15-2020, 12:12 PM | #2 |
Re: Rear End Swap
If both are coil spring trucks it should be a straight up swap.
There is no "factory" gear ratio. You will have to count rotations or pull the cover and look at the numbers on the ring gear (which you should be doing anyways to change fluid at least, if not, replace axle seals too). I always recommend an adjustable track bar if you have the $$. Then you can center the diff.
"Work hard, use your vacation days." 1970 C15 GMC Long Bed 1986 C20 Scottsdale 1983 K2500 Sierra Classic Suburban 6.2 Instagram: C10sofOC |
05-15-2020, 03:40 PM | #3 | |
05-15-2020, 03:41 PM | #4 |
Re: Rear End Swap
Will this be a direct swap?
Posted via Mobile Device |
05-17-2020, 10:32 AM | #5 |
Re: Rear End Swap
I found most 1/2 ton trucks i have played with are 3.73 ratio
my 72 is 3.07 so best to open it up check the stamped numbers on the ring gear and change the axle seals as well not to just save your brakes to save your swapped diff as well |
05-17-2020, 10:40 AM | #6 | |
The Older Generation
Re: Rear End Swap
There is a "standard" ratio from the factory depending on the engine/transmission combination, unless there is an option listed on the SPID on the inside of the glove box door. LockDoc
05-18-2020, 06:55 AM | #7 | |
Re: Rear End Swap
When I spin the yoke and count I get about 2.25 turns of the yoke to 1 turn of the wheel. That seems slightly higher than I was expecting. Do you know what the highest options available for that year Suburban were? |
05-18-2020, 08:37 AM | #8 | |
Re: Rear End Swap
Not off the top of my head I don't. My '69 Suburban had a 3.08 gear in it and I ended up changing it to a 3.73. Look at this thread. http://67-72chevytrucks.com/vboard/s...d.php?t=578793 Check out posts # 8 & 19 for the code locations. You only use the first two or three letters of the code number. LockDoc
